Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Anti-virus Not updating (6.0.6)
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-21
06:32 AM
2013-05-21
06:32 AM
Hi ,
I have noticed that Anti-Virus signature files dose not update unless I reboot or disable /enable the service. Dose anyone know if this correct or just another software issue ?
Thanks
Andrew
ReadyNas 104 S/W 6.0.6
Thanks
Andrew
Message 1 of 19
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-21
08:04 AM
2013-05-21
08:04 AM
Re: Anti-virus Not updating (6.0.6)
I find this to be the case as well.....
Message 2 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-21
08:31 AM
2013-05-21
08:31 AM
If you have SSH, you can trigger a manual check for update on the A/V signatures.
# /frontview/bin/avdu -v 3They have gone out of their way to hide command line arguments from people for some reason.
avdu.c:481(3) defId: 0-->201305211449
avdu.c:291(3) Start downloading definition file (201305211449)
avdu.c:303(3) Done downloading definition file (201305211449) rc=0 http_status=200
avdu.c:502(2) Successfully download definition file (201305211449)
avdu.c:330(3) Start installing virus definition file (201305211449)
avdu.c:356(3) Success installing virus definition file (201305211449)
avdu.c:519(2) Successfully installed new definition file (201305211449)
Message 3 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-21
10:04 AM
2013-05-21
10:04 AM
Thanks Chirpa
Is it possible to schedule the task to run daily ?
Andrew
Andrew
Message 4 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-21
10:24 AM
2013-05-21
10:24 AM
It looks like it is scheduled in some manner. I've seen it periodically update between 3-7 days on one system. It's not a crontab job though, must be internally scheduled in the readynasd agent. Though I last saw that with 6.0.5 and lower. They keep stripping stuff in the newer versions, like hiding the command line arguments, its possible something could be broken in 6.0.6, haven't looked in detail at that release.
Message 5 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
05:42 AM
2013-05-24
05:42 AM
Hi..
Just noticed my AV had updated after a week of being powered on >>> Would prefer once a day NetGear..
Andrew
Andrew
Message 6 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
06:22 AM
2013-05-24
06:22 AM
I am wondering if the AV updates are pushed (e.g., not scheduled, but updated when they change).
Message 7 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
06:58 AM
2013-05-24
06:58 AM
StephenB Not sure , but if you reboot or disable/Enable AV it load a new Signature file almost every time ..
Andrew~
Andrew~
Message 8 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
09:44 AM
2013-05-24
09:44 AM
StephenB, they are pulled. It checks http://0001E241P1281I072105:@avdl.ctmai ... ir-hit.ini to see if the available definitions date is newer than what it has, then downloads it.
Message 9 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
10:53 AM
2013-05-24
10:53 AM
Then it should either check often enough that no one cares, or you should be able to set the schedule (agreeing with AndrewT's desire for more frequent updates).
Message 10 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
11:19 AM
2013-05-24
11:19 AM
Until we find out how they schedule it, a cronjob script could be created which runs /frontview/bin/avdu on a defined schedule.
Message 11 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
05:15 PM
2013-05-24
05:15 PM
Found it. Runs 10 minutes after boot, and once a week after that.
You should be able to edit that file to be 1d instead of 1w. But firmware updates would overwrite the changes.
# cat /lib/systemd/system/avdu.timer
[Unit]
Description=Anti-Virus Definition Update Timer
Requires=ctscand.service
[Timer]
OnBootSec=10m
OnUnitActiveSec=1w
Unit=avdu.service
Message 12 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
10:57 PM
2013-05-24
10:57 PM
Does anyone know what antivirus engine is used ? Is it ClamAV or another one ?
Message 13 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
11:00 PM
2013-05-24
11:00 PM
It's CommTouch. A generic provider, many embedded systems use their AV definitions.
viewtopic.php?p=389048#p389048
http://www.commtouch.com/antivirus-for-nas/
It's the same AV that runs on NTGR's STM/UTM product line.
Message 14 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-24
11:07 PM
2013-05-24
11:07 PM
Thanks chirpa. If I'm not wrong, it's OEM, not free. Can we use it on x86 legacy with "legal" use ?
Message 15 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-25
02:41 AM
2013-05-25
02:41 AM
Thanks Chirpa
Going to mood the file and see what happens ...
Andrew~
Andrew~
Message 16 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-25
04:46 AM
2013-05-25
04:46 AM
chirpa wrote: Found it. Runs 10 minutes after boot, and once a week after that. # cat /lib/systemd/system/avdu.timer
[Unit]
[Timer]
OnBootSec=10m
OnUnitActiveSec=1w
Unit=avdu.service
Thanks Chipra! You need to send Netgear a consulting bill as I have learned and addressed more issues from you than opening a ticket with Netgear.
Message 17 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-25
01:49 PM
2013-05-25
01:49 PM
It's in the OS without protection to stop it from being used on non-OS6 official boxes. So if it comes down to it, the OEM provider may bitch to NTGR for license violations. Same goes for Paragon NTFS driver they include in the OS.
glem wrote: Thanks chirpa. If I'm not wrong, it's OEM, not free. Can we use it on x86 legacy with "legal" use ?
edit: wow, they've turned on profanity filters now haha.
Message 18 of 19
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-25
01:50 PM
2013-05-25
01:50 PM
I had offered to do work for them after I left. But I think I've annoyed them more than anything, helping users out on here; being outspoken and defending the community they have abandoned. Brett (PLM for business storage) banned me on the NTGR forums for pointing out beta releases they put on their anonymous FTP site (link in my sig). They sent me a cease and desist letter last year based on bogus claims by one employee... it's sad what they've turned into.
Govnah wrote: Thanks Chipra! You need to send Netgear a consulting bill as I have learned and addressed more issues from you than opening a ticket with Netgear.
Message 19 of 19
