Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Change from Ultra 2 Plus to 314 using same disks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-01
12:48 AM
2013-08-01
12:48 AM
Hi
I've a new 314 arriving today to replace my Ultra 2 Plus. I'd like to move the existing disks to the 314 without losing the data (permanently) or copying it back to a PC first. Whats the best & fastest way?
My Ultra 2 Plus is configured RAID 1 mirror, so I'm guessing:
- Remove disk 2 from Ultra 2 Plus
- Install it as disk 1 in 314
- Allow it to initialise & wipe the data.
- Copy all of the intact data from disk 1 on the Ultra 2 Plus to the 314 - this is where I'm unsure
- remove the remaining disk from the Ultra to the new NAS & it will sync?
Any assistance appreciated.
Regards
John
Regards
John
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-01
12:57 AM
2013-08-01
12:57 AM
Re: Change from Ultra 2 Plus to 314 using same disks?
Don't a factory default via the boot menu would wipe the disk. Yes this should work but you should ensure your backup is up to date first.
Yes. You could run a backup job (e.g. Using Rsync) on the 314
You would need to delete the partitions off the disk first (e.g. hooking the disk up to a PC). If this is too difficult I could wipe the disk remotely for you whilst it is still in the Ultra 2 Plus if you like.
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-01
03:02 AM
2013-08-01
03:02 AM
Thanks for the prompt response
I'm not too worried about losing the data on one of the mirrored disks. Once I've removed it from the Ultra, I'll check the remaining disk is fine.
Wasn't aware that I needed to delete the partitions, so thats handy to know. I'll give it a go & if I come unstuck I'll post back here.
Regards
John
Regards
John
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-01
04:00 AM
2013-08-01
04:00 AM
I agree with mdgm that you should do a backup first. Alternatively buy one new disk, put it in the RN314, and then copy/migrate as you wish.
The risk with your method is that if there is an undetected bad sector on drive 1, you will lose data (since once you pull out drive 2 you lose redundancy).
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-02
02:14 AM
2013-08-02
02:14 AM
First stage complete - I've mimicked the share names on the new device & used Rsync to copy them all across.
I notice on the latest version of RAIDar, that there is an option to use disks that have previously been used in another device. Can I simply add the second disk now & format it in the 314 with this option?
Regards
John
Regards
John
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-02
02:43 AM
2013-08-02
02:43 AM
I'm not sure but I think this option is for if you have only put used disks in the NAS and want to wipe them all.
So instead of simply showing the corrupt root error on boot the NAS would prompt you that you may wish to format your disks if you have put used disks in.
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-02
02:52 AM
2013-08-02
02:52 AM
So perhaps I could:
- Remove the now working disk 1 from the 314
- Install the remaining disk 2 from the Ultra
- Format it in the 314 then remove it
- Re install disk 1
- Install the formatted disk 2 & it should sync from disk 1?
Regards
John
- Re install disk 1
Regards
John
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-02
02:56 AM
2013-08-02
02:56 AM
Not sure that that would work either. Will send you a PM.
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-08-03
01:30 AM
2013-08-03
01:30 AM
Destroyed the partitions off the disk to be wiped using "sgdisk - Z /dev/sdX" (no quotes and where X is the drive letter) and it is now resyncing.
Message 9 of 9
