pasan's avatar
pasan
FTP user authenticated access issues - Error code 15002040001
I have enabled FTP access on 2 of my file shares with access permissions Everyone, admin +RW. My understanding is this will allow only authenticated users to access the shares via FTP.
However, when I try to access the shares from a FTP client, I can't login with my user credentials. More alarmingly the FTP server is allowing unauthenticated anonymous R/W access! When I go to settings and check global FTP settings it is showing authentication mode as "Anonymous".
So I thought ok well maybe this explains this behaviour and tried to change it. However when I chage the Authenticaiton mode to "User" and click apply, I get the following error - Service operation failed. Cannot start service without volume Code: 15002010001.
I am puzzled why this is happening. For starters, FTP access permissions for shares does not even have "anonymous", yet the global settings have an anonymous authentication option which I cannot change.
My desired behaviour is for ReadyNAS to have authenticated FTP access. This shouldn't be this complicated. Please help.
I am on the latest firmware version 6.6.1
  • Checked the logs, the only clue found is the error log "cannot enable dlna when no volume exists",   I am thinking if there are some settings about ReadyDLNA block the operation.  Can you try  disable ReadyDLNA firstly ?  Then try to edit FTP settings.
    • pasan's avatar
      pasan
      Hi FramerV,
      I have emailed my system logs as per the linked instructions.
      Hope the subject matter expert can explain the cause of this issue and a solution that won't involve resetting the ReadyNAS and deleting all data on it.
      Thanks.
      • FramerV's avatar
        FramerV
        NETGEAR Employee Retired
        Hi pasan,
        Let me have it checked.
ProSupport for Business
