× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN104 Retry Startup
logmein
RN104 Retry Startup
Hello,
My RN104 doesn't boot up normally. Display shows "Retry Startup" and Power LED keeps blinking forever.
Tried the following with no luck :
1) Booted up in OS Re-Install which completed successfully but next regular boot again goes to "Retry Startup"
2) Connected each disk drive to a PC and scanned for errors ( used SeaTools from Seagate) and found no disk errors whatsoever.
3) I have 3x3TB disks in X-Raid. Removed one disk with other 2 intact and booted up. Get the same behavior for all the disks.
4) Had a chat with Tech-Support who instructed me to boot via tech support mode which was successful but they couldn't help me further as my device is out of 90 days free support.
Please help !
Message 1 of 3
Nhellie
Virtuoso
Re: RN104 Retry Startup
Did you test booting the chassis without any disk?
Seeing previous cases like the this appears only to be fixed by remote access through SSH/TelNet, so if I were you I would get a one-time fee based support from tech support, unless you have a backup where you can just reset to factory.
see cases:
viewtopic.php?f=64&t=80525
viewtopic.php?f=64&t=78172
Message 2 of 3
logmein
Hi Nhellie, Thanks for you quick response !
Yes i did boot without disks but got error telling no disks present.
Can you please guide me to or provide me the link to avail one-time only support ?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2368 views
  • 0 kudos
  • 2 in conversation
Announcements
