× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN3130 Management service is offline
Interlab15
Hi,
RAIDar notifie me that i can't access to my NAS and i can't download logs or make a diagnostic.
I am under firmware 6.8.0 and it is since this update that i can't connect to my NAS, all services are disable exept HTTPS i can't enable SMB to restore my data.
I have tried to réinstall the OS by the boot menu but it didn't solve my problem. I have many important data on it to restore. Someone can help me ?
Thanks for your answer.
*Sorry for my english.
Model: ReadyNAS-3100|ReadyNAS-3100
Message 1 of 7
Guru
Re: RN3130 Management service is offline
Can you log into the admin web ui?  ( https://nas-ip-address/admin )
If so, try downloading the NAS logs from there.
Message 2 of 7
Interlab15
I can't,
I have a loading bar "Connecting to the ReadyNAS Admin Page..." at the end i have this message : " ReadyNAS Admin Page is offline".
Message 3 of 7
Guru
If https://nas-ip-address/fwbroker responds, then try manually installing 6.8.1 through that interface.
What apps and services do you have running on the NAS?
Message 4 of 7
Interlab15
Last time i succed to connect to my NAS, only HTTPS was running, and when i try to go to https://nas-ip-address/fwbroker i have this message : Internal Server Error...
Message 5 of 7
Guru
Paid support (my.netgear.com) is probably your best option.  You can boot the system into tech support mode, and they can access it remotely.
You can ask about per-incident support, which will cost less than a service contract.
Message 6 of 7
Interlab15
Ok thank you for answer.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1007 views
  • 0 kudos
  • 2 in conversation
Announcements
