- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN516 - Management service offline after 6.4.0 update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear all,
Since 6.4.0 update I have issue and now :
Management service is offline
Somebody can help me because can't do reset factory due to backup is not uptodate.
Thank you.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I contacted Netgear Support : they solved my problems on RN516 since 6.4.0 update. 🙂
Then do the same contact them 🙂
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: RN516 - Management service offline after 6.4.0 update
I have the same Problem since i updated to 6.4.
Johannes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Management Service is Offline is caused by the service readynasd not being started. If it has a problem being started, then the UI will not work properly and most things will be unavailable. There are many factors that may cause this to happen. If you have SSH enabled, dig around and see what it says about readynasd system (try systemctl status readynasd)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Thats what the command say:
readynasd.service - ReadyNAS System Daemon
Loaded: loaded (/lib/systemd/system/readynasd.service; enabled)
Active: activating (start) since Sun, 18 Oct 2015 17:04:00 +0200; 7min ago
Main PID: 3986 (readynasd)
Status: "Initialize"
CGroup: name=systemd:/system/readynasd.service
â 3986 /usr/sbin/readynasd -v 3 -t
â 3988 /bin/sh -e /run/proc_readynasd.hwKlsc
â 3989 find / -maxdepth 2 -mindepth 2 -name ._share -type...
Oct 18 17:04:00 JDNas readynasd[3986]: readynasd log started
Oct 18 17:04:01 JDNas readynasd[3986]: readynasd started. (restarted=0)
A minute later:
Active: activating (start) since Sun, 18 Oct 2015 17:14:01 +0200; 57s ago
Main PID: 4039 (readynasd)
â 4039 /usr/sbin/readynasd -v 3 -t
â 4041 /bin/sh -e /run/proc_readynasd.Ojmjqk
â 4042 find / -maxdepth 2 -mindepth 2 -name ._share -type...
Oct 18 17:14:01 JDNas readynasd[4039]: readynasd log started
Oct 18 17:14:01 JDNas readynasd[4039]: readynasd started. (restarted=0)
I have a ReadyNas 102. Since the update from 6.2.5 to 6.4 it worked fine.
I also tryed to reinstall 6.4 vie USB-Stick, but nothing changed.
Johannes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
In addition to my previous messages:
I let it run since yesterday afternoon.
There is every 10 minutes a new File in the /run directory:
-rwx------ 1 root root 194 Oct 19 20:04 proc_readynasd.MqdlOe
-rwx------ 1 root root 194 Oct 19 19:54 proc_readynasd.FVMds5
-rwx------ 1 root root 194 Oct 19 19:44 proc_readynasd.KZwPIV
-rwx------ 1 root root 194 Oct 19 19:34 proc_readynasd.bgFGBP
-rwx------ 1 root root 194 Oct 19 19:24 proc_readynasd.qzBxhG
and so on.
Any Idees?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can't access to SSH I can only access to telnet with techmode enable. 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN516 - Management service offline after 6.4.0 update
I have also flashing light after update 6.4. Management service offline. RN102 with 2x1 TB HD. No solutions by far?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I still have the Problem. I can see the Volumes under Windows and browse the Directorys but i cant use (read, copy, move,delete) Files.
So it is un usable
I have made a zip-file with the logs. Is there a way to upload them, so somebody can analyze them if it is helpful ?
Thanks for help
Johannes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Laurent
How did you contact them ? I can't find an E-Mail Address, only Phonenumbers where i have to pay for the call.
Thanks for Help
Johannes
- Mark as New
- Bookmark
- Subscribe
- Permalink
You likely have lifetime free chat support via support.netgear.com.
On the phone line, make it clear you have a 6.4.0 upgrade issue, and I think if you are insistent enough they won't charge.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
you can contact by chat or online form here : http://www.netgear.com/support/contact.aspx?cid=gwmng
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
Thanks for the Help. It was solved via remote session.
Johannes
