interested
Sep 09, 2011Tutor
RSYNC downgrade or upgrade ???
Hi.
What is the right way to downgrade or update RSYNC ???
Becouse of some problems I would like to downgrade to RSYNC 3.0.6
apt-get remove rsync ( ver. 3.0.8 )
apt-get install rsync .....
apt-get upgrade rsync ....
New & latest ver. of Rsync is 3.0.9pre1
BUG FIXES:
- Fix a crash bug in checksum scanning when --inplace is used.
- Fix preservation of a symlink's system xattrs (e.g. selinux) on Linux.
- Fix a bug with the modifying of unwritable directories.
- Fix --fake-super's interaction with --link-dest same-file comparisons.
- Fix the updating of the curr_dir buffer to avoid a duplicate slash.
- Make daemon-excluded file errors more error-like.
- Fix some issues with the post-processing of the man pages.
BUG FIXES:
- mdgm-ntgrNETGEAR Employee RetiredYou could compile Rsync 3.0.6 from source. I don't know if NetGear's makes any modifications to Rsync or not to get it to work nicely on the ReadyNAS. Rsync 3.0.6 is found in the GPL for RAIDiator x86 4.2.11. See http://www.readynas.com/gpl
- compile is a strong word for Windows user :(
- mdgm-ntgrNETGEAR Employee RetiredI think you do
apt-get update
apt-get install build-essential
Then change the working directory to the rsync-3.0.6 folder (use "cd" command), then run "make" (no quotes). - You have probably better things to do, als writening a dummy manuals for compilation ?
- mdgm-ntgrNETGEAR Employee RetiredSeeing my ReadyNAS units are in production use, I don't want to break them. It shouldn't be very hard to compile. There is a README file in the Rsync-3.0.6 folder explaining what needs to be done.
Just had a look and here's what you need to do
apt-get update
cd /path/to/rsync-3.0.6
configure
make
ls -la
You should see the binary of rsync you just built. Assuming it's called "rsync", I think you'd need to do:
cp -f rsync /usr/bin/rsync
EDIT: would suggest following WhoCares' expert advice. Much better than what I suggested doing. - WhoCares_MentorAs another workaround one could grab a copy of the older GPL sources archive and compile the rsync version found in there using the "dpkg-buildpackage" utility which would produce a .deb file that can be installed using "dpkg -i {name of .deb file}". This would have the advantage of the libraries being used by rsync getting replaced, too.
-Stefan WhoCares? wrote: As another workaround one could grab a copy of the older GPL sources archive and compile the rsync version found in there using the "dpkg-buildpackage" utility which would produce a .deb file that can be installed using "dpkg -i {name of .deb file}". This would have the advantage of the libraries being used by rsync getting replaced, too.
-Stefan
Who is willing to help us to compile the rsync 3.0.6 from RAIDiator x86 4.2.11 ( http://www.readynas.com/gpl) ???
I did try all other things ...- WhoCares_MentorOnce I'm back in my office (this time tomorrow would be quite likely) I can give it a spin.
-Stefan - TNX to user WhoCares which has compiled rsync 3.0.7, here is a solution:
1. I did stop the RSYNC in frontview, under SERVICES > STANDARD FILE PROTOCOLS
2. with program like putty I connected to my NAS using SSH
3. write the the following commands:
Code:
wget http://whocares.de/rpro/rsync_3.0.7-1~bpo50+1_i386.deb
dpkg -i rsync_3.0.7-1~bpo50+1_i386.deb
4. start RSYNC again, , under SERVICES > STANDARD FILE PROTOCOLS
5. do the backup job
After all, the backups under 4.2.19 working again :D :D :D
