Orbi WiFi 7 RBE973
Reply
Reactivate missing volume
Brt85
Follower
Hi Team,
I had a problem with access to my NAS. No web - "device is offline" message, No access to any volumes. I try power off gracefuly, but with any effect. After 1hour I use "hard-boot". When system come back, I update firmware manually OS 6.2.5 --> 6.9.1(directly)
After that OS looks stable, but I can't access to my data (check screen). In option's i have only "destroy" volume.
In logs i found info: "Volume: System volume root's usage is 100%. This condition should not occur under normal conditions. Contact technical support"
I'll be very greatful for any help.
How can I Reactive volume?
Model: RN10400|ReadyNAS 100 Series 4-Bay (Diskless)
Message 1 of 2
Guru
Re: Reactivate missing volume
It would be best to use paid support for this (my.netgear.com).  You can ask for per-incident support.
Wait until after Christmas of course.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 571 views
  • 0 kudos
  • 2 in conversation
Announcements
