× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Ready NAS 104: identify failing drive
Saram
Hi,
This morning I heard clicking noises (click of death?) coming from my Ready NAS 104. I shut down the device and when I turned it on there were no more clicks. Regardless, I want to change the drive that was making click noises.
I checked the logs but there are no error messages other than hard drive capacity warnings like
"Volume: Less than 20% of volume Disk-04's capacity is free... "
Upon checking the HDD status I got the following:
            HDD one has ATA error: 103
            All others have ATA error: 0
I wanted to confirm if HDD one should be replaced
I appreciate your help.
Antonio
Ready NAS 104
Firmware 6.10.4 hotfix 1
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 3
Accepted Solutions
Guru
Re: Ready NAS 104: identify failing drive
It is concerning, though one question is whether the count is growing or stable.
ATA isn't the only one that matters - you can see the others by downloading the log zip file, and look in disk-info.log.
I suggest running the disk test from the volume settings wheel.  That might restart the clicking.  After the test, download the logs again and take another look at disk-info.log and see what changed.
BTW, if a disk is clicking, it should be replaced no matter what the count is.
Message 2 of 3
All Replies
Guru
Message 2 of 3
Saram
Hi
Thank you. I downloaded the log and I found the info I needed:
Health data
ATA Error Count: 103
Reallocated Sectors: 420
Reallocation Events: 82
Spin Retry Count: 0
Current Pending Sector Count: 442
Uncorrectable Sector Count: 351
Temperature: 38
Start/Stop Count: 9653
Power-On Hours: 40523
Power Cycle Count: 107
Load Cycle Count: 827101
Hard drive one is failing. I will replace it once I get the 4TB WD Red plus I ordered today.
Thank you again.
Antonio
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1108 views
  • 1 kudo
  • 2 in conversation
Announcements
