- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
ReadyNAS 104 Inaccessible - ReadyNAS Admin Page is Offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 104 Inaccessible - ReadyNAS Admin Page is Offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 104 is not a rack-mount unit. If your unit is rack-mount and you have mis-identified it in this chain, the help you are getting may not be correct.
USB recovery is not done via the boot menu. But since I am no longer sure what NAS you have, I can't point you to the right process. But assuming it's at least an OS6 based system, you can find them here: How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system .
- Mark as New
- Bookmark
- Subscribe
- Permalink
THE 104 IS NOT A RACK MOUNT
Yes, I know; my first post identifies my NAS as a "ReadyNAS 104, running System 6.10.7, with 4 x 2TB drives."
As stated above, I've prepared a USB drive for USB recovery, but there's no CLEAR indication of which files should be installed on the USB drive.
Are the files listed in this image the correct files to be included on the recovery USB?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Started Boot from USB recovery, but errored out to Failed!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not quite. Delete the ulmage-recovery file, and rename the READYNASOS-6.10.8-arm.img file to ulmage-recovery (with no file extension).
Was the drive formatted as instructed?
- Find a USB drive with a capacity that is greater than 256 MB, but no more than 32 GB.
- Ensure that the USB drive has only one partition.
- Format the USB drive as FAT, FAT-32, or MS-DOS file system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. I tried FAT-32 and also MS-DOS
I'll make the changes to the files and try again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reformatted the USB drive as MS-DOS (FAT) and copied/renamed the files as instructed--see below.
Unfortunately, I'm still getting Failed! error shortly after the NAS boots into USB Recovery mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried USB recovery with a different thumb drive with the same result--Failed!
What's my next option?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can see my NAS and shares in ReadyCLOUD, and I see firmware update is available.
I'm tempted to give the upgrade a go since everything else seems to be failing.
Is this a crazy idea?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can also see and open the shares in my NAS in the browser interface.
Maybe I should attempt the firmware upgrade while the browser interface is active?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something must have changed as a result of all the reboots and recovery attempts.
I can see my NAS and contents in ReadyCLOUD and my NAS and shares are available in the browser interface, including my apps (Transmission, qBittorent, Plex), and the apps are functional.
What's the quickest way to backup my NAS before initiating a firmware update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
DO YOU HAVE ENOUGH STORAGE TO BACK IT UP?
I have a 4TB USB drive that will accommodate all the data I want to backup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One option is to connect the disk to the NAS, and use one or more ReadyNAS backup jobs. These would run unattended, so they wouldn't tie up your Mac. You should double check that the files look ok before you proceed - one way to do that is to eject the disk, and connect it to the Mac for checking. I recommend using a disk format that you can read on the Mac - NTFS is probably the best option for you. One benefit here is that you can set up a schedule to update this backup automatically.
You can also connect the disk to your Mac, and transfer all the files over the network. It would be best if you could connect the Mac to your network with ethernet. The benefit here is that you can use the native APFS formatting. If you go this route, you should look for a transfer tool that can copy everything for you - FreeFileSync is one that might work. Note I am not a Mac user, so this might not be the best choice.
Either way, you should put a backup plan in place going forward - RAID isn't enough to keep your data safe.
- Mark as New
- Bookmark
- Subscribe
- Permalink
After multiple shutdowns/boots into OS re-install, I'm getting better access to my "broken" NAS, and I'm now able to backup my most valued files. The NAS is indicating that it's in backup status (blinking backup led), but I have no idea how many of my files have been backed up, and I don't want to interrupt the process. My first attempt at backup only backed up a limited number of files before the NAS dropped out of backup status. I was able to mount the USB drive I used for backup to my Mac and see and access the files that had been backed up. After rebooting into another OS re-install and initiating another backup, I noticed an error message in the browser access page. It looks like my number 1 drive is in the process of failing, so this may explain the NAS's erratic betahaviour, because the NAS OS is on the number 1 disk, as I understand it. I'm mentioning this in the hope this might help someone else in a similar predicament in the future.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just noticed the error is now identified as disk 4—looks like I may have 2 drives on the way out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Managed to back up my essential files, removed the failing drive and replaced with another, let the RAID rebuild then installed the most recent firmware update. Everything is now much more responsive.
Thanks for all your assistance.
- « Previous
- 1
- 2
- Next »
