- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 3138 (OS 6.10.5 hotfix 1) no space left after I deleted a share
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello to everybody,
I got the same problem into 2 different old ReadyNAS model (RN3138 and RN2100).
The problem is that when I delete a share, the free space didn't increase but it kept the same before.
I just deleted a total amount of 4TB of a share and now I continue to have only 60GB of free space; the total volume amount is of 5.6TB (4 * 2TB sata disks in RAID 5).
There are no snapshots; the btfrs command line doesn't shows any (and I deleted them too); the du command line shows only 1.3TB of occuped space in /data; the df comman line shows there is 99% of space in use.. Where is gone the space used after the share deletion?
I ready on this community forum that there are many people had the same problem and that the only solution is to delete the volume and re-create everything... Can somebody to help me please?
I attached only one screenshot because the system doesn't permit me to add anymore.
Thanks in advance.
Ciao!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 3138 (OS 6.10.5 hotfix 1) no space left after I deleted a share
Try running a balance from the volume settings wheel, and let us know if that helps.
Also, please post the output of
btrfs fi df /data btrfs fi du -s /data
Normal df and du don't give a good indication of where the space is going.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
btrfs fi us /data -b
might also give some good information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello StephenB,
this is the result:
Overall: Device size: 5986292072448 Device allocated: 5921753268224 Device unallocated: 64538804224 Device missing: 0 Used: 5920943214592 Free (estimated): 64601485312 (min: 32332083200) Data ratio: 1.00 Metadata ratio: 2.00 Global reserve: 240353280 (used: 0) Data,single: Size:5909874999296, Used:5909812318208 /dev/md127 5909874999296 Metadata,DUP: Size:5905580032, Used:5564825600 /dev/md127 11811160064 System,DUP: Size:33554432, Used:622592 /dev/md127 67108864 Unallocated: /dev/md127 64538804224
Thanks again
Ciao
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I forgot to notice you that balance, scrub, etc didn't produced any effect.
Ciao
- Mark as New
- Bookmark
- Subscribe
- Permalink
The system is definitely thinking that the allocated space is all used.
Maybe use btrfs fi du -s /path on each of your subvolumes, and see if that gives you any clues on where the space is going.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really many thanks for your reply.
I already ran those commands and they show that there is occuped only 1,8TB in a volume of 5.6TB but the free space is 60GB. I just deleted the volume and I recreate it. This seems to be the only slution to apply, like many other people done before me.
Thanks
Ciao!
