× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Volume error on readynas 4220
stbatpierret
Dear,
I just received an error
"System volume tmpfs's usage is 89%. This condition should not occur under normal conditions. Contact technical support."
Logged with ssh i found
root@nas-4220-1:/run# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev             10M  4.0K   10M   1% /dev
/dev/md0        4.0G  1.5G  2.2G  42% /
tmpfs           3.9G     0  3.9G   0% /dev/shm
tmpfs           3.9G  3.4G  457M  89% /run
directory is filled with a lot of files  export_db_background.xxxxx. More than 800000 with each 866 bytes
Running midnight commander show me the following files and size according the picture
Any ideas for the existence of such export_db files ?
Thanks in advance for your support
Model: ReadyNAS-4200|ReadyNAS 4200
Message 1 of 3
Guru
Re: Volume error on readynas 4220
Not sure where those files are coming from.
But I am wondering if you have tried rebooting the NAS?  tmpfs is a temporary file system (like a ramdisk, but it can be swapped out).
Message 2 of 3
stbatpierret
Thanks for the info
I carefuly moved these files to a temp directory and partition space recovered to something normal.
I still do not understand why these files were created.
I will continue to check in the folliwing days.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 641 views
  • 0 kudos
  • 2 in conversation
Announcements
