Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo won't update with latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
09:52 AM
2012-10-12
09:52 AM
Hi,
I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed:
Fri Oct 12 17:12:13 WEST 2012 Problem encountered while updating your ReadyNAS device.
These are the ReadyNAS details:
Model: ReadyNAS Duo [X-RAID]
Firmware: RAIDiator 4.1.6 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
Other than that, everything else seems to be working fine.
Thanks
MT
Thanks
MT
Message 1 of 48
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
10:00 AM
2012-10-12
10:00 AM
Re: ReadyNAS Duo won't update with latest firmware
Hi,
Can you download the file and then upgrade the firmware using the local image. In this way the unit will verify the image file first for errors. if you already tried this, go ahead and do OS-re install first.
Message 2 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
03:10 PM
2012-10-12
03:10 PM
Thanks for the reply. Yes, I've tried this method before and it hasn't worked. OS re-install sounds a bit of a job. I've got a lot of stuff on there. Is this the only way to fix this problem? Any idea as to why it might be failing to update?
Message 3 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
04:17 PM
2012-10-12
04:17 PM
Hi,
The other option is to call Netgear tech support and open a case.
Message 4 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
04:22 PM
2012-10-12
04:22 PM
OS Re-install leaves data intact.
atanas if motah33 has had the unit over 90 days a free online case may be preferable.
Message 5 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-12
08:38 PM
2012-10-12
08:38 PM
Thanks for the replies. I've had the ReadyNAS for quite a while now - over 3 years I think. I'll open a case with Netgear and take it from there.
Regards
MT
Regards
MT
Message 6 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
11:16 AM
2012-10-20
11:16 AM
I did open a case with Netgear, although they haven't responded for a while. They asked me to do an OS reinstall which I did but I don't think it completed properly. After a long time, I could see a pattern on the leds that were blinking and it looks as if it was saying that there is something up with the flash (I found the meaning of the patterns on this forum). It makes sense because when I tried again to update the firmware, this time downloading the file to my hard drive then uploading it, it said that the flash verification failed. I also found the USB ports aren't working. I bought a qualified UPS for it and it isn't recognised and neither are any USB hard drives (I tried two). So, I don't know if a complete factory reset is going to do anything here or if the hardware has gone south.
Message 7 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
01:27 PM
2012-10-20
01:27 PM
Are you able to run the memory test?: http://www.readynas.com/kb/faq/hardware/is_there_a_way_i_can_verify_if_my_memory_is_good
Message 8 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
04:42 PM
2012-10-20
04:42 PM
Thanks for the reply. Just running it now... If it is the memory would that explain the USB issue too or are they unrelated? I've never used the USB ports until now (with the UPS). Netgear support has got back and asked to do a full factory reset. I would like to try whatever checks I can before doing that. The data has been backed-up including the configuration file.
Message 9 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
06:53 PM
2012-10-20
06:53 PM
It's possible that bad memory would prevent a firmware update from working. If the memory is fine, then further investigation would be needed. There's a good explanation of the memory test on the Duo here: http://www.readynas.com/forum/viewtopic.php?f=11&t=26993
Message 10 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
07:02 PM
2012-10-20
07:02 PM
It's been running for a while now and I noticed the squence with the disk1/disk2 leds went as follows: 10-01-11-00 (I think). Then, the act led came on and the disk1/disk2 leds went off. It's been stuck in this state for a long, long time whereas the other sequences went quite quickly. I don't know if the tests are any differenct with the act led on but it certainly stuck here. If this is signifying a memory problem, then what is the spec of original memory in the Duo so that I can get a replacement?
Message 11 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
07:07 PM
2012-10-20
07:07 PM
motah33 wrote: It's been running for a while now and I noticed the squence with the disk1/disk2 leds went as follows: 10-01-11-00 (I think).
That just indicates the test is running.
I think it should be both disk LEDs lit when it's finished but I'm not sure. Maybe the result when it's finished would be both LEDs off. Have you tried powering off the NAS and running the test a second time?
Message 12 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
07:31 PM
2012-10-20
07:31 PM
Trying it again... I think it might have been ok. I realised that that disk leds aren't as bright as the act one. But I will run the test again. I was looking at the logs and I found the following in the system.log file after I boot. I don't know if this is anything to worry about:
Oct 21 03:24:46 readynas kernel: Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
Oct 21 03:24:46 readynas kernel: 0x00000000-0x00100000 : "P0 flash partition 1"
Oct 21 03:24:46 readynas kernel: 0x00100000-0x04000000 : "P0 flash partition 2"
Oct 21 03:24:46 readynas kernel: NEON flash: probing 8-bit flash bus
Oct 21 03:24:46 readynas kernel: CFI: Found no NEON flash device at location zero
Oct 21 03:24:46 readynas kernel: NEON flash: unknown flash device, mfr id 0x1, dev id 0x0
Oct 21 03:24:46 readynas kernel: NEON flash: Found no Atmel device at location zero
Oct 21 03:24:46 readynas kernel: This board is not supported.
Message 13 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
08:51 PM
2012-10-20
08:51 PM
May have to run the memory test again. This time, it ended up with all 3 leds off for quite a while and so I switched it off. I hit the power button and I had to wait quite a while before it rebooted itself. I'll run the test again to see if it does it again. It does the sequence with disk 1 led being on and then you can see it moving through a pattern.
Message 14 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
08:58 PM
2012-10-20
08:58 PM
Looking around hunting for clues, I found this partition.log:
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 500.0 GB, 500097376256 bytes
255 heads, 63 sectors/track, 60800 cylinders, total 976752688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 976736305 486064152 5 Extended
/dev/hdc5 4608003 976736305 486064151+ 8e Linux LVM
No idea what this is about.
Message 15 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
09:00 PM
2012-10-20
09:00 PM
That looks normal.
So you have SSH access?
Message 16 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:22 PM
2012-10-20
10:22 PM
Funny you should say that as I've just inststalled the add-on. I presume I need some sort of terminal program to get access to it?
Message 17 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:25 PM
2012-10-20
10:25 PM
I just want to say that I appreciate all the help, mdgm.
I'm going to have to disappear soon but if you want to give me some things to try, please feel free and I'll run through them and get back the results.
Support want me to do a factory reset but I thought I'd like to investigate some more if we can.
Message 18 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:37 PM
2012-10-20
10:37 PM
Are you on a Windows PC or a Mac?
Message 19 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:38 PM
2012-10-20
10:38 PM
I'm on PC running Windows XP SP3. I've got PuTTY running and I can log in to the ReadyNAS.
Message 20 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:39 PM
2012-10-20
10:39 PM
O.K. Start by posting the output of the following commands:
# df -h
# df -i
# ls -la /tmp
Message 21 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:42 PM
2012-10-20
10:42 PM
readynas:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 361M 1.5G 19% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 462G 272G 190G 59% /c
readynas:~#
readynas:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 256000 10697 245303 5% /
tmpfs 7073 1 7072 1% /USB
/dev/c/c 15204352 111733 15092619 1% /c
readynas:~# ls -la /tmp
total 123308
drwxrwxrwt 4 root root 4096 Oct 21 06:09 .
drwxr-xr-x 22 root root 4096 Oct 21 06:10 ..
drwxr-xr-x 2 root root 4096 Oct 21 05:59 addons
-rw-r--r-- 1 root root 206611 Oct 18 06:04 config.zip
-rw-r--r-- 1 root root 13 Oct 21 06:09 .dhcp_server
drwxr-xr-x 2 root root 4096 Oct 21 04:52 log_zip
-rw-r--r-- 1 root root 62948864 Sep 20 19:01 RAIDiator-4.1.10
-rw-r--r-- 1 admin admin 10 Oct 21 06:40 ttt.log
-rw-r--r-- 1 admin admin 62943744 Oct 21 06:02 update_file
Message 22 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:46 PM
2012-10-20
10:46 PM
Hmmmm. Looks like update_files is probably 4.1.9.
Please do e.g.
Can you also do
Please do e.g.
# rm /tmp/update_file
Can you also do
# cat /var/log/raidiator_version
# cat /.cf_update_in_progress
Message 23 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:49 PM
2012-10-20
10:49 PM
RAIDiator!!version=4.1.6,time=1247518584
The second command gives me:
readynas:~# cat /.cf_update_in_progress
cat: /.cf_update_in_progress: No such file or directory
Message 24 of 48
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-20
10:51 PM
2012-10-20
10:51 PM
Yes, I did try with 4.1.9 too which might explain the update_file. It's been deleted.
Message 25 of 48
