Kymru's avatar
Kymru
ReadyNAS NVX Business Edition problem
I have had this unit for over a year, up until a month or so back its been working fine
I mainly use it for downloading via flexget and transmission, so only TV episodes and films on it
about a month ago all devices on my network started to disconnect and reconnect every few minutes or less, doesn't matter if they are wired or wireless, after trying various routers without success, i finally worked out it was the ReadyNAS NVX
when its connected to the network, all devices including the NVX disconnect then reconnect, when its not connected to the network, all devices work fine
i have tried using Lan 1 and Lan 2 (still disconnects), tried both together (still disconnects), tried resetting the NVX to factory default (same thing)
updated the firmware to RAIDiator 4.2.27 (same thing)
i am completely confused as to why this happens when the NVX is connected to the network
i have tried a few different routers
2x Netgear DGN2000
2x Netgear DG834GT
1x Linksys WAG354G v2
has anyone got any suggestions what i can try next?
ProSupport for Business
