kennethmacleod's avatar
Jul 10, 2010
ReadyNas Duo USB Share - Write-Protected
Hi All,
I am looking for some help. I have a Netgear ReadyNas NV+ running perfectly. I also have a Netgear ReadyNas Duo running perfectly. I have a Western Digital 2TB USB drive which I have plugged into the Duo and it sees it perfectly and I can format it to whichever file system I see fit. My problems then start. I am unable to write to the USB drive even though I can see it in Windows & Mac operating systems.
The ReadyNas shows up the correct size of the USB volume, the name of the share is correct but I cannot write to it. The odd thing is that when I first formatted it to Ext3 (I have also tried NTFS & FAT) was that I was able to transfer a large set of files onto it. I am now unable to add anything else onto it.
I have the following permissions enabled.
CIFS - Read/Write Enabled with 'Allow guest access' ticked
AFP - Read/Write Enabled with 'Allow guest access' ticked
HTTP/S - Read/Write Enabled
In Advanced options I am unable to change the share folder owner and group to anything other than root. I am not sure if this is the issue or not but I had the same symptom on FAT & NTFS.I have 'Grant rename and delete privileges to non-owner of files' ticked.
I have exhausted most online searches and forums with this query so this is why I am posting it. I hope someone will be able to point me in the right direction as it is much better for me to have the USB drive plugged into my NAS.
Thanks in advance
ProSupport for Business
