× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Rn214 not recognizing external usb drive
Scuttle
When I plug my seagate backup plus hub, 8tb, into my ReadyNAS it doesn’t show up on the interface. It’s causing me to transfer all the data over WiFi and so far a couple TB has taken a week. I’ve tried all the USB ports, is there a reason it’s not recognizing it? Is it the size?
Model: RN214|4 BAY Desktop ReadyNAS Storage
Message 1 of 5
Hopchen
Prodigy
Re: Rn214 not recognizing external usb drive
Hey
Could you share what exact model USB drive this is?
Cheers
Message 2 of 5
Scuttle
It’s a Seagate Backup Plus Hub 8tb, formatted xfat.
Im running firmware version 6.9.5, recently updated.
Message 3 of 5
Guru
@Scuttle wrote:
xfat
That's not a supported format.
https://kb.netgear.com/7009/ReadyNAS-OS-6-USB-Port-use wrote:
  • USB drives should have BTRFS, EXT2/3, FAT32 or NTFS format.
So reformat it as one of these (ideally NTFS if you also need to connect it to a PC).
Message 4 of 5
Scuttle
Yeah, figured that out eventually. I’ve just been using exfat for a few years on externals because it goes from Mac to Windows pretty seamlessly and I run both. Didn’t even imagine it was unsupported. I’ll reformat my backup drives once I backup all the data to the NAS (sometime next month?).
Thanks for your help.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1878 views
  • 0 kudos
  • 3 in conversation
Announcements
