× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Switch drive positions
Campus
Apprentice
Hi,
is it possible to shutdown the system, re-arrange the drive positions and start again without data loss?
Thanks
Campus
Model: RN716X|ReadyNAS 716X Chassis
Message 1 of 4
Guru
Re: Switch drive positions
Why would you want to?  The only case I can think of where it might be useful is if you want to put empty slots between drives to reduce temps.
It's supposed to work, but...
Message 2 of 4
Campus
Apprentice
That's exactly the use case. I switched to 8TB drives and they run pretty hot. Unfortunately only one is one the top line but three fill all slots on the bottom. So I would like to move them into the corners so more air is in between them.
Message 3 of 4
Guru
It should work, perhaps give Netgear a chance to confirm.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2214 views
  • 0 kudos
  • 2 in conversation
Announcements
