× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyOS 6 Issue with Large Volumes (missing space)
powellandy1
Virtuoso
Hi
This is a follow on from - https://community.netgear.com/t5/Using-your-ReadyNAS/Adding-a-4th-10TB-drive-to-a-XRAID-array-on-Pro...
I've placed the 4x10TB and 2x6TB drives in the 516 and factory reset.
It is only showing a 27TB volume.
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid5 sda3[0] sdf3[5] sde3[4] sdd3[3] sdc3[2] sdb3[1]
      29278364160 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU]
      [>....................]  resync =  1.5% (92339416/5855672832) finish=482.5min speed=199047K/sec
md1 : active raid6 sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1] sda2[0]
      2094848 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU]
md0 : active raid1 sdf1[5] sde1[4] sdd1[3] sdc1[2] sdb1[1] sda1[0]
      4190208 blocks super 1.2 [6/6] [UUUUUU]
unused devices: <none>
/dev/md/0:
        Version : 1.2
  Creation Time : Sat Aug 18 20:44:59 2018
     Raid Level : raid1
     Array Size : 4190208 (4.00 GiB 4.29 GB)
  Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
   Raid Devices : 6
  Total Devices : 6
    Persistence : Superblock is persistent
    Update Time : Sat Aug 18 20:52:20 2018
          State : clean
 Active Devices : 6
Working Devices : 6
 Failed Devices : 0
  Spare Devices : 0
           Name : 0ed5d010:0  (local to host 0ed5d010)
           UUID : 6f9e2c56:3498cd6e:706c27f3:97c019e0
         Events : 19
    Number   Major   Minor   RaidDevice State
       0       8        1        0      active sync   /dev/sda1
       1       8       17        1      active sync   /dev/sdb1
       2       8       33        2      active sync   /dev/sdc1
       3       8       49        3      active sync   /dev/sdd1
       4       8       65        4      active sync   /dev/sde1
       5       8       81        5      active sync   /dev/sdf1
/dev/md/1:
        Version : 1.2
     Raid Level : raid6
     Array Size : 2094848 (2045.75 MiB 2145.12 MB)
  Used Dev Size : 523712 (511.44 MiB 536.28 MB)
   Raid Devices : 6
  Total Devices : 6
    Update Time : Sat Aug 18 20:45:18 2018
          State : active
 Active Devices : 6
Working Devices : 6
 Failed Devices : 0
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 64K
           Name : 0ed5d010:1  (local to host 0ed5d010)
           UUID : 5a9e34db:a32bc6cd:f723f220:62cfff8d
         Events : 18
       0       8        2        0      active sync   /dev/sda2
       1       8       18        1      active sync   /dev/sdb2
       2       8       34        2      active sync   /dev/sdc2
       3       8       50        3      active sync   /dev/sdd2
       4       8       66        4      active sync   /dev/sde2
       5       8       82        5      active sync   /dev/sdf2
/dev/md/data-0:
        Version : 1.2
  Creation Time : Sat Aug 18 20:45:16 2018
     Raid Level : raid5
     Array Size : 29278364160 (27922.02 GiB 29981.04 GB)
  Used Dev Size : 5855672832 (5584.40 GiB 5996.21 GB)
   Raid Devices : 6
  Total Devices : 6
    Update Time : Sat Aug 18 20:50:21 2018
          State : active, resyncing
 Active Devices : 6
Working Devices : 6
 Failed Devices : 0
  Spare Devices : 0
     Chunk Size : 64K
  Resync Status : 1% complete
           Name : 0ed5d010:data-0  (local to host 0ed5d010)
           UUID : 86bd18e6:9f28a484:85e22e96:9b3d249e
         Events : 6
       0       8        3        0      active sync   /dev/sda3
       1       8       19        1      active sync   /dev/sdb3
       2       8       35        2      active sync   /dev/sdc3
       3       8       51        3      active sync   /dev/sdd3
       4       8       67        4      active sync   /dev/sde3
       5       8       83        5      active sync   /dev/sdf3
It doesn't seem to have created the second array across the 4 10TB drives.
I thought the whole point of XRAID was it was supposed to pick this up automatically.
Will it find it on a reboot?? should I factory reset again?? do it manually??
Thanks
Andy
Model: RN51600|ReadyNAS 516 6-Bay
Message 1 of 6
Accepted Solutions
Guru
Re: ReadyOS 6 Issue with Large Volumes (missing space)
@powellandy1 wrote:
Correct. I've only just reset.
I've rebooted it it and nothing changed (although I accept it might not as it's in the middle of a rebuild).
Just leave it until the resync completes.  It won't start on the second RAID group until it's done with the first one.
Message 4 of 6
All Replies
Guru
It looks to me like the resync isn't finished - is that correct?
Message 2 of 6
powellandy1
Virtuoso
I checked with the XRAID calculator and it should be 38TB.
I'm just mindful of the issue I had with the Pro6 when the 4th drive didn't expand properly and mdgm kindly did it manually but it lost XRAID and therefore the ability to seamlessly expand in the future... I was hoping a factory reset would have found all 38TB initially.
I've used mdadm -G before to expand a volume but in this case there isn't a md126 to expand.... and I would have thought there should be...
Thanks
Andy
Message 3 of 6
Guru
Message 4 of 6
powellandy1
Virtuoso
My bad... I was expecting it to allocate both at once. Thank you.
Kind regards,
Andy
Message 5 of 6
powellandy1
Virtuoso
All sorted. 38TB as expected.
Thanks
Andy
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1167 views
  • 0 kudos
  • 2 in conversation
Announcements
