meural frame
16 TopicsMenus keep popping up
We often find that our Meural Canvas is displaying menu information even though we haven't gestured or used the app to see it. Not only is it annoying to have to take deliberate steps to make the menus go away, but our Canvas does not seem to react easily to gestures so it often takes multiple attempts. it'd be great to know what's causing this - maybe subtle changes in lighting in the room, mistaken for gestures? Adjusting the light sensitivity has made no difference, unfortunately. I understand that it's not possible to completely turn off the light or gesture sensor. Is there something else we can try that we're not thinking of?20Views0likes0CommentsMeural Canvas unable to upload
Hello, For now months I have been unable to upload pictures from my iPhone or my MacBook to Meural. I haven't changed phone, I still have space on my Canvas, etc. Pictures are not oversized and are in the right format. I tried just one picture at a time... Support is unresponsive (tried many time to call but no one picks up). I'm very disappointed for a premium product, would not recommend to anyone - stay away from it. Any help?223Views2likes5CommentsMeural Frame screen black and unresponsive
My Meural II canvas has been fairly reliable until this week when the screen went black and on the website it shows "offline". I tried a different compatible power adapter thinking that might be the problem with no success. Now, the My Meural section of the website is giving me an error message. "400 Bad Request". I know the canvases are no longer being produced and they can't be bought from Netgear anymore but has all support and operations ceased? Thanks.76Views0likes0CommentsImage Upload Broken
Unable to upload photos to my Meural Canvas. It fails in the app, and fails with the web version too. I've attempted photos I've previously uploaded to the Canvas -- standard JPGs taken from my iPhone. The API seems to be returning a 500. This has been happening for days. Please fix, as I deleted a whole bunch of photos and galleries, and am not able to upload anything new. This is not a space issue. I have 3.8gb of space remaining. Thank you416Views4likes10CommentsUpload Error
Over the past week, I've been getting "Upload Error" whenever I try to upload photos to my Meural playlist from my computer. I'm uploading .jpg files and have even tried to upload photos that I have previously uploaded successfully. Any ideas? Anyone else having this issue? Thanks. Art225Views0likes3CommentsMeural App No Longer Able to Control Meurals
As of this morning the Meural app no longer seems able to control my Meurals. It cannot select images in my playlists, cannot sleep or wake the Meurals, cannot use the directional buttons. I've checked that the app (iOS) is on the latest version and the Meurals are as well (2.0.9) and have tried rebooting the Meurals and the app, logging in and out, all the usual troubleshooting. Is anyone else experiencing this? How can I fix this?193Views1like2CommentsMeural 2 - What's Up...Discontinued or Not - Help!
Aloha Netgear, I own a considerable amount of your products. I have owned numerous routers (Nighthawk, etc.) and Mesh WiFi systems (Latest being the Orbi 970 + 2 Satellites), and high speed LAN switches, etc. I also own (or have owned) 5x Meural 29" photo frames: 3x of the original 29" photo frames (2x Photo Frames failed), so I purchased a replacement Ver 1 and then when the Ver 2 was made available I purchased 2x of the Meural II photo frames - of which 1 of the newer Ver 2 photo frames has also failed). It's frustrating to say the least that the failure rate is so high. To date, I have not taken any specific actions to get these photo frames repaired because my experience is that the displays are too time consuming and difficult to repair. So, you could say that despite the issues I've encountered, I'm invested. I do have to further state that Netgear further frustrates me because there is absolutely nowhere - anywhere - where I can find new / replacement Meural II 29" frames. As noted above, I've had 2x original Meural photo frames fail and 1 of your Ver 2 Photo Frames fail. This has been a very frustrating experience - especially given that we had the cords run in our walls to hide them - makes for a wonderful clean look, but now I'm stuck unless I want to switch to a different manufacturer. I have searched high and low for the 29" Meural 2 photo frames, but they are literally impossible to come by these days....this is, I suspect, others who own these large format photo frames and have also expressed concerns that Netgear has (or will be soon) discontinued your Meural product. Given that no one has any available, I too share this same concern 4 months later. These photo frames are quite expensive all things considered and I hope that you continue to produce and support this product. Please advise on status of the Meural 2 (or replacement) production and availability. Thank you. John F. Pacific Aerials and Photography542Views0likes2CommentsPossible to use both cloud and SD storage?
Hi, like many others, I have run out of space in my cloud storage on my Meural II. I like the cloud interface - it’s super buggy, but I like that I can just select photos from my phone and send them to the Meural instantly vs download. However, I need more space. I know that there is an SD card option. Is there a way to use both the cloud and the SD card? Or do I have to use one or the other? I currently use the scheduler option to have different playlists show at different times of day (ie. “travel” plays from 2pm - 4pm on Friday but from 10am-noon on Saturday - i do this with 5 playlists and rotate them so I see different photos all the time). I have 2 questions : is there a way to integrate the SD card and the cloud so that I can see photos from playlists on both? Or do I have to go all in on SD card to really make it work? Can i have rotating playlists from the SD card? Or do they just play in order - playlist1 (image 1 - 100 in order), then playlist2 (image 1 - 100 in order) and so on? the SD card is just way less convenient for taking a photo and adding it same day. I’d love to keep that functionality for at least some of my photos if possible many thanks542Views0likes1CommentMeural Canvas II Server Status Offline
Hello, My Canvas II is unable to connect back to the server. The last sync as 7.22.2025. The server status is offline, but my wifi is connected with IP Address. The software version is 2.3.2_3.0.3. My family has other canvas that is running software version 2.0.9 and no issues connecting to the server.714Views0likes4Comments
