ekhalil
Jul 11, 2019Master
New Firmware 2.3.5.30
Just updated my Orbi to 2.3.5.30. Seems stable so far.
I see few "ads" for the Orbi app and links for app download in the web GUI.
Otherwise I could not see much more new things. I'm keeping to look and will report if I find new things.
The Support Download page does not yet show this SW.
- ekhalilMaster
The page that was called QoS under >> ADVANCED >> Setup is now called "Speed Test" as it should.
- pchiccino1Aspirant
seeing config sync issue with this release as well, anyone else see this?
Is daisy chaing enabled or disabled?
Using combined SSIDs and not separate?
pchiccino1 wrote:seeing config sync issue with this release as well, anyone else see this?
Just updated a RBK50 system via autoupdate and select update all. Upgrade smooth.
No config sync seen. GOOD is the status of the RBS connected via wireless.
I'll be posting some WAN to LAN speed results soon:
Automatic update worked for me. Was not as speedy as I had expected, but smooth. Seems to be working OK.
One change I had not expected. The Attached Devices page had an announcement at the top that Access Control is turned on and new devices are blocked from connecting. This was not how I had it configured before the update. Would have been a lot of head-scratching if this had updated silently and I unboxed a new device. Oh, yes. No more "silent updates". But still, I would have expected the update to keep Access Control settings as they were. It kept most of my device tables the way they were, but it changed two smart switches from Allowed to Blocked.
what mode are you running in?? is it AP or Router? I don't see the access control section you are speaking of, I have a ton of smart switches and devices and this will be a huge problem for me if it's on..
- RayandbrendaAspirant
I'm not sure about everyone else, but I didn't spend the amount of money on the Orbi just to have Netgear use the config screens for graphics to download an app I already have (referring to the graphic for the Orbi app in the new firmware). Would be nice if Netgear would clean the interface up some instead of cluttering it up more or better yet add some features that are missing.
- PsyberonAspirant
So...just noticed this and updated. Seems to have gone fine;I think it took 5 or 6 minutes, just long enough for the kids to notice. :smileytongue:
I[m not seeing any release notes. Anyone know what’s changed...?
- clammerdsApprentice
The release notes from the interface tiself stop before they're finished (they don't even exist in the raw html) but here is what we can see :
Release Notes:
[Bug Fix] Fixes issues with the Apple HomeKit connectivity.[Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress.
[Bug Fix] Fixes the WiFi disconnection and IOT issue.
[Bug Fix] Fixes the guest isolation issue for multicast and broadcast traffic between the main host and guest.
[Bug Fix] Fixes the Ethernet backhaul boot-sequence issue.
[Bug Fix] Updates the OpenVPN certificate from MD5 to SHA-256.
[New Features and Enhancements] Circle Parental Controls support for India.[New Features and Enhancements] Auto Time zone detection feature and setting.
[Bug Fixes] The client was not able to obtain an IP address when the router rebooted or the client renewed the IP address.
[Bug Fixes] The iOS speed test uploaded the throughput issue in PPPoE mode.
[Bug Fixes] Issues with the Japanese language string.
[Bug Fixes] The user wasnt able to log in to the GUI after finishing the GUI installation.
[Bug Fixes] The router GUI could not be accessed using oribilogin.com or orbilogin.net.
[Securi
I'm guessing this next one is a security fix. Anyway, already from the list, it's worth updating!
- pablohoneyLuminary
I tried updating my Orbi RBR 50 and RBS50. The status on the RBR50 is "Update failed" and the status on the RBS50 is "V2.3.5.30". How do I fix the "Update failed" issue?
- Retired_Member
I don't do manual updates.
Does this update qualify as a 'auto' update?
Retired_Member wrote:I don't do manual updates.
I did it via the Auto Update page on the web interface.
- Retired_Member
Thanks
I'm wondering if this update qualifies for a NG push?
I was told by the NG support folks that the only updates that will be pushed are those with with major changes. Others are at the users preference.
- XUSIBROAspirant
Did the update successfully this afternoon. No idea how long it took, as I left the house. Things appear to be stable and normal. The only recent issues I was experiencing was a couple HomeKit light switches dropping out, presumably this is solved. Time will tell.
Be sure to do a new backup config to file for safe keeping. Mines online as of today offically. Looking good here. RBS is wired. No Config Sync issues.
- chuydvAspirant
I updated the firmware through the app and seems to connect fine to the internet, but (there is always a but)... now I am unable to connect to the Orbi App and the only way is to access remotely. Additionally my wired conection to Orbi is not recognized and connects it automatically to my spectrum modem, so I cannot access to routerlogin.com.
Does anyone have seen this? I hate to reset and connect again 20+ devices again. Ugh
- gr8shoVirtuoso
chuydv wrote:I updated the firmware through the app and seems to connect fine to the internet, but (there is always a but)... now I am unable to connect to the Orbi App and the only way is to access remotely. Additionally my wired conection to Orbi is not recognized and connects it automatically to my spectrum modem, so I cannot access to routerlogin.com.
This is the archtypical concern that some of us have, Which is to say that the in place update when carrying over changed settings from stock leaves the system in a state where seemingly strange behaviors are observed, at which point the only viable recourse is to factory reset and clear out the entire network which can take hours of time to do correctly in a large family home.
Try orbilogin.com for Orbi web page.
- Chp66AspirantUpdated firmware manually through the iOS app. WiFi was dropping on and off. Did factory reset on router and satellites. WiFi still continues to drop and come back up. No problems before update.
- Joboo7777Apprentice
Upgraded RBR50 & RBS50 using auto upgrade through safari browser with no issues.
I run ALL default settings(no changes from factory) except:
- Set Static Open DNS IPs instead of using Auto ISP DNS
- Enable Implicit Beamforming in Advanced Wireless Settings
- Enable MU-MIMO in Advanced Wireless settings
I dont run Armor, Family Circle, or guest network. And I dont separate SSIDs
Come back and let us know how it performs or if you see any other problems. Running similar setup here as well.
Enjoy.
Joboo7777 wrote:Upgraded RBR50 & RBS50 using auto upgrade through safari browser with no issues.
- Swimmer63Aspirant
I have an RBR50 with two RBS50 Satelites. I went to check if I needed a firmware update. iOS app always says no. So I logged into the RBR50 UI on my phone. Sure enough it set an update was needed. I hit update and waited.
When I restarted the UI I had version V2.3.5.30. I could not remember if that's what I had or not. So I tried logging into netgear.com.
After 30 minutes of trying to log in, including changing my password twice I gave up and just started browsing support.
In support it showed the current update as being V2.3.1.60. No where could I find anything higher than this version. Am I dense? Why do I have firmware that's a number of iterations past what is listed on the website?
Welcome to "Orbi World". You have every reason to find the situation puzzling. Previously, Netgear had the Orbi set up to update firmware automatically on a signal from Netgear. (Some) Users were upset and angry when their networks updated and things stopped working. Netgear started a beta program for "early adopters", but that still didn't address the problem.
So, these days, Netgear routers will "discover" that a new firmware is available when the user happens to navigate to web interface, and it's up to the user if they want to update or not. Meanwhile, some other people at Netgear who maintain the support web site will eventually decide it's time to put the new firmware on the support site for download.
So, YES, the firmware you have is the "latest" firmware. Since you posted on this thread, you are aware that lots of people have installed it. Some are happy (me), and some are definitely NOT happy.
Those gadzillions of Orbi customers who never look at the Orbi web interface are blissfully unaware, and probably happy to be so. At some (future) point, Netgear will probably force a firmware update on them, and they will (most likely) still be blissfully unaware. UNLESS, of course, something "goes horribly wrong", in which case they may find this user forum and post a question.
Try a factory reset on the RBR and setup from scratch.
Swimmer63 wrote:I have an RBR50 with two RBS50 Satelites. I went to check if I needed a firmware update. iOS app always says no. So I logged into the RBR50 UI on my phone. Sure enough it set an update was needed. I hit update and waited.
- varaseGuide
I upgraded each satellite, then the main router, but when everything came back up had a speedtest problem where the speed would clock in at less than half of my allowed bandwidth.
So ... I reset the cable modem, power cycled the RBR50, and power cycled each of the RBS50s and waited for everyone to resume talking to one another.
Result: speedtest came back with anticipated speed, and all seems to be well.
Thanks for letting us know. Seem to take a power cycle and a few minutes for the system to settle in. Glad it's working for you. Enjoy.
varase wrote:I upgraded each satellite, then the main router, but when everything came back up had a speedtest problem where the speed would clock in at less than half of my allowed bandwidth.
