AmitR
Apr 23, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 availability
A quick update. We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models. When it goes live, you should see a prompt in the Orbi Mobile App (or the WebUI) to upgrade your firmware. In addition to the connectivity fixes in 2.1.3, has a few additional bug fixes from the last release (2.1.3).
Orbi Product Mangement
- BobDukeApprentice
The Orbi app offered to update my system this morning. Good way to do it.
The update went smoothly, as have all past updates since I installed in December. I needed to restart the Orbi app to refresh it's data.
I have not needed to do a factory refresh. My configuration had always been transferred automatically through each update. I don't remember all the version numbers, but I started in 1... to 2.0.. to 2.0.?.18 to 2.1.3.4 to 2.1.4.10.
All working well so far.
- tsigLuminary
Update mine via the app last night. Very disppointing. No drama at all. After about 5 minutes or so everything was working as normal with no issues at all.
Glad the update went smoothly and you haven't had to factory reset. Some haven't had any problems during or after updates. Thats good as well. Factory reset is recommended if you do encounter problems.
Enjoy.
HomeKit still broken.
Back to 2.1.2.18.
Your next update should really include the 'no update' option. :)
30-40 minutes of my time to roll back every time is getting tiresome.
- Sdiver2489Apprentice
I updated because the interface offered it to me. It went smoothly so far. I'll see if the Rainmachine issues continue or other weird random issues.
- RJDStar
When I updated my RBK50 (both router and satellite) to 2.1.3.4 I reset everything but still had issues with the satellite. When the RBW30 2.1.3.6 firmware was released I updated those, reset and added to the RBK50 router and was goind relatively well. A few drops here and there but nothing major.
I then updated the router to 2.1.4.10 via the web gui upgrade and both RBW30's now drop in and out a lot so have turned them off until a 2.1.4.x update is available for those. I am not resetting everything again as have had enough of doing that and as per various comments updating from 2.1.3.4 to 2.1.4.10 via an upgrade instead of using BETA software shouldn't require a full reset again.
I tested again with the RBK50 satellite (RBS50), updated, reset it and connected but as I noticed before bugger all devices will connect to it and continue to connect to the router so have just swtiched that off as no point wasting electric.
will await RBW30 firmware before testing those again.
- kc5grwInitiate
As so many others have stated THERE NEEDS TO BE A NO UPDATE OPTION AVAILABLE!!!! I saw the update last night and installed it. It worked for a few minutes then I lost connectivity completely. My ORBI router sits in my office at the front of the house where my modem is. One satellite in my master bedroom closet connected wirelessly. The second satellite connected via ethernet backhaul upstairs at the back of my house. The system was stable under 2.1.2.18. I rolled back to 2.1.2.18 after 2.1.4 hosed everything. All was back to normal. Then I wake this morning to find that 2.1.4.10 was installed again on the system and again loss of connectivity. Rolled back to 2.1.2.18 again this morning and will have to check again at lunch if it has gone to 2.1.4.10 again. I haven't tried factory resetting it all yet. I guess I have to see if that works.
When coming from older v2.1.x.x FW there are some major changes when loading v2.1.4.10. So please do a full factory reset on the router and satellites then set up from scratch. Should see better results. Others have mentioned this as well.
- Retired_Member
The idea of recommending/forcing people to perform a factory reset is bogus. IMHO this would appear to be an easy fix that could be applied with each update and FW install tool, much like a web browser clears its cache. Many folks have personal settings, passwords, etc that require time to reload if a factory reset is perfomed. Don't make it harder than it needs to be.
- DanimalCTutor
I have been plagued with Wi-Fi dropping for months now. So two days I ago I decided to manually upgrade my RBR50 and RBS50 sattelite to v2.1.3.4 and everything was working good! Then last night I lost internet connection twice. I logged into the webUI and noticed that they both updated automatically to v2.1.4.10 without my knowledge or input (of course the day after I finally got them working well). My RBW30 updated to 2.1.3.6 automatically as well. Each time a reboot of the router fixed the internet issue. This morning when I woke up I didnt have internet over Wi-Fi again, a reboot fixed the issue again. I tried downgrading my router to 2.1.3.4 but it was unsuccessful. Tonight I will try factory resetting everything and seeing if that helps. I just wish I had the option to install the update and that these firmware upgrades worked better.
Let us know if doing a factory reset after applying v2.1.4.10 and set up from scratch helps. .
- erikrubinAspirantIs there a preferred or recommended procedure for performing a factory reset? I have a system with 2 satellites. After upgrading to 2.1.4, I get extensive and long duration dropouts on my Nest Outdoor cam.
New version 2.1.4.10 auto-installed while I was away. No paper clip reset done after this update.
I wait and see what happens thus let you know.
- eljarvisoLuminary
Has homekit/mDNS broadcast been fixed in this release?
Have had a STABLE connection 6 WEEKS ON 2.0.1.4!!! Now the udate to 2.1.4.10 has screwed that all up. Router resets every 15 to 60 minutes. Both router and sateltie are on 2.1.4.10 and both have been factory reset. Still resets keep happening. Going to reset to 2.0.1.4 again. If this keps happening will be getting rid of Netgear product and going else where. This has been going on for far to long.
Whats the Mfr and model of the ISP modem that the Orbi router is connected too?
Any wireless neighbors near by? If so, how many
What channels are you using? Try manual instead of Auto.
Fw update should try a full factory reset on all units then set up from scratch.
What is the distance between the router and satellite? 30feet minimum to start.
Whats the size if your home? SqFt.
- Retired_Member
Got the 2.1.4 update through the web GUI. Took just a few minutes and all appears to be in order. No factory reset. Wish me well.
May the force be with us all...............
After being forced to auto update to 2.1.4.1 the Orbi has been absolutely terrible. Websites intermittent loading, poor performance satellites losing connection., etc. Ths firmware is unusable. I was on 2.1.3.4 with no problem. I have spent about 3 hours on the phone with tech support and here is where I stand.
Tech support told told me not to plug in one satellite for fear it might be creating interference. Don’t use Ethernet backhaul. And currently I can download 170mbs if my computer is hardwired into the router, but wireless speed is 20mbs download when the device is 10feet from router (connected to router, not satellite). With no physical object blocking signal.
System ran fine in 2.1.3.4, now it’s terrible. Worst thing is the auto firmware update. I can do a thing about it.
Unbelievible. I think I will have to return it to Costco. My family and myself are losing our minds.
What is the Mfr and model# of the ISP modem the Orbi is connected too?
Please try a factory reset on the router and satellite and set up from scratch and let us know if this changes anything.
- gertgTutor
I have RBK50 with 3 RBS30 Satellites. Previous 2.1.3.4 firmware worked almost ok after hard reset both router and satellites except no or very slow response from Homekit devices.
This new 2.1.4.10 is unstable even after hard reset, losing devices, Homekit doesn’t seems to work.
It would be nice to have check box for Autoupdate option.
- Sevo123ApprenticeWhyyyyyy!!!! My rbk53 olus (hardwired rbr50) took a **bleep** from last night! Been over 12 hours connection issues!! I probably power cycled , hard reset 10 times this stupid firmware is pissing me off and Netgear is aswell! Garbage honestly they try to fix couple issues they create other issues!! Whyyy did I update whyyy!!! Netgear doesn’t know what they are doing some workers need to be FIRED ASAP!!!!!!
