Kuikenj's avatar
Kuikenj
Poor stability, frequent disconnects
Hello,
I purchased an Orbi RBK53 with two sattelites from Costco. I moved into my new place, installed my cable ISP (spectrum) and have had frequent disconnects and interupptions in my Wifi capability from the Orbi. It disconnects about 1-2x per hour!
I work from home, and I'm not a tech expert, but the cable isn't having an issue while the Orbi disconnects. I expect to be able to take this thing out of the box, plug it in and have it work. I fired the unit up on 7/26, so it should have the latest firm ware.
If this can't be fixed quickly, its going to go back to Costco and I will find a router that is stable! Help!
  • plemans's avatar
    What firmware are you on?
    How large is your home?
    How far apart are the orbi devices? They need 30ft minimum in between them.
    Is it all devices loosing wifi? Or is it specific devices?
    Have you tried changing wireless channels?
    When you loose connection, are you having to manually reconnection or what process do you use to fix the problem?
    • Kuikenj's avatar
      Kuikenj
      4000 square foot home, main unit on first floor, wifi satellite on 2nd floor and another separate satellite (not daisy chained) in basement
      all devices lose connection
      firmware v2.3.1.48
      have not changed wireless channels (how do I do that?)
      router more or less resets and reconnects, but it takes a few minutes. and in the meantime, I lose my network connection to work
      • FURRYe38's avatar
        What is the distance between the router and satellite(s)?
        Change channels by logging into the RBRs web page. Advanced tab/Setup/Wireless Settings.
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Kuikenj wrote:
    Hello,
  • FURRYe38's avatar
    You might want to upgrade the system to v30 as that is the most current version of FW. Update the RBS first, then the RBR lastly. Factory reset the RBS and RBR and setup from scratch. Walk thru the setup wizard with a wired PC and web browser.
    • Kuikenj's avatar
      Kuikenj
      Ok, I’ll attempt to change the channel and update the firmware etc. Currently having difficulty logging into the router. I’ve cleared the cache and its saying router isn’t connected to the network, when clearly it is or I wouldn’t be able to respond. :-)
      • FURRYe38's avatar
        Try a different wired PC. Try using 192.168.1.1 as well...
    • Kuikenj's avatar
      Kuikenj
      I have updated the firm ware to V30.
      I have changed the manual channel to 6 on 2.4 ghz
      i have enabled beamforming and mimo
      Unclear If it worked or not.
      • FURRYe38's avatar
        How are the RBS placed in relation to the RBR? Out in a line or in a star configuration?
        Daisy Chain is for RBS that are placed out in a line from the RBR and having two or more RBS. Might have to play with this some.
        Whats the status of the RBS say? Good?
  • Retired_Member's avatar
    Retired_Member
    Call Spectrum and confirm that your modem is in the bridge mode and not allow any NAT functions. Tell them you're using a NG Orbi ROUTER.
    • FURRYe38's avatar
      The model modem they have doesn't have a built in router.
        Retired_Member
        i would still call.  Too many people are buying the Orbi without knowing what type of modem they have.  The call is free.
  • Kuikenj wrote:
    ............... have had frequent disconnects and interupptions in my Wifi capability from the Orbi. It disconnects about 1-2x per hour!
    What type of devices do you have attached to Orbi? Which ones are wired and which are wireless?
    Retired_Member
    Kuikenj wrote:
    Hello,
    what was your old router?
