ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M internet connection in Hong Kong with maximum speed around 450-550M in my other router - ASUS RT-AC68U. This Orbi only runs around 250M something. I'm very disappointed.
- StefanuTutorSame problem with connection here. And I already installed the V2 firmware from orbi
Turning WiFi off and on re-establishes the connection.. - cadfostAspirant
Is the RBR50 still incompatible with Samsung Galaxy? Will be getting a new router if so.
- gondekInitiateThis issue of the S8+ dropping from orbi wifi seems to have been re-introduced with the most recent phone update http://doc.samsungmobile.com/SM-G955F/TEL/doc.html a tell tale sign is the orbi app not being able to connect to the RB50 router. Need to raise this issue with Samsung, wondering if amyone having this problem again since S8 October 2018 update and their orbi? so frsutrating
- MarcNettTutor
Same type of problem with S9 and Note 8, seems working and next day no connexion.
What FW is currently loaded?
How was the FW updated on the Orbi? Auto update or manual FW file load?
Has a factory reset been performed then set up from scratch?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926Does any of this help?
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
