manageddatacomm
Jan 10, 2016Aspirant
Fs728tpv2 unable to access web interface over VPN
Firmware version 5.2.0.39 Loca subnet 10.201.190.0/24 Able to access from local subnet Can't access over VPN tunnel I have eliminated VPN as the cause, as I'm able to access web interfaces of...
DaneA
Jan 11, 2016NETGEAR Employee Retired
Hi manageddatacomm,
Welcome to the community! :)
Kindly answer the questions below:
a. Is Flow Control enabled on the FS728TPv2 switch?
b. Is the FS728TPv2 the only device in the remote LAN that is just capable of 100Mbps of ethernet connection that you are having trouble accessing its web-GUI via the VPN tunnel?
c. Have you tried to reboot the FS728TPv2 switch and check if same problem occurs?
d. Have you tried to perform a factory reset on the FS728TPv2 switch then reconfigure it from scratch and check if same problem occurs?
I look forward to your response.
DaneA
NETGEAR Community Team
