Drekko
Sep 02, 2017Aspirant
JGS516PE - SNMP support? Monitor Temps
hi Does this switch have SNMP ? I want to be able to monitor its tempretures remotely
DaneA
Sep 04, 2017NETGEAR Employee Retired
I'm afraid to inform you that there is no option to monitor the temperature neither through the web-GUI of the JGS516PE nor using the ProSAFE Plus Configuration Utility. Also, there is no option to have a console connection to the JGS516PE switch.
DaneA
NETGEAR Community Team
Drekko
Sep 04, 2017Aspirant
DaneA
Damm
I guess a taping a thermometer to the switch is the only way to go lol
