Gedruspax
Oct 04, 2021Star
Airbridges act erratic then drop completely until power cycle.
I have 3 WBC502 airbridges (firmware is the latest version as of this posting on 10/4). One of them is mounted to my main building one and two are across a parking lot as satilittles in an airbridge group. They are setup in my insight managment portal.
The main unit will only stay up for about 10-20 minutes or so after a boot up. After that it becomes unresponsive to pings or web requests or insight management and thus the other 2 fall off as well. The only way I can fix it is to physically go and power cycle the power brick that came packaged with the unit (Yes I am using the designated power bricks that shipped with the units.)
So i'll walk over, power cycle it, a minute later they all come back up in my insight portal and I can ping them again and reach their web interfaces. Then about 10-20 minutes later down they all go.
I sat in the web interface of both the master and one of the satillites as long as I could before it dropped off so I could copy as much of the log files as I could.
Keep in mind that this is the 2nd master unit I've had. I spent a ton of time with support and eventually after turning off spanning tree on the switchport that the power brick is plugged into which is ALSO a netgear switch that is in my insight portal by the way (GS752TPP). Also have all POE turned off on port the brick is in as well.
I've tried turning the spanning tree on and off on the bridges themselves that doesn't help either.
So a few things i'm noticing in the MAIN (Master Unit) before it goes down everytime there are a large number of association events in the log right before it dies that look like this
2021-10-04T15:49:52.342989-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:49:43.207844-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 WPA: WPA/WPA2 authentication successful
2021-10-04T15:49:43.205747-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 WPA: pairwise key handshake completed (RSN)
2021-10-04T15:49:43.132099-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: associated
2021-10-04T15:49:42.914799-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:49:40.897861-05:00Z WBC502 kern.info kernel: [ 219.400214] br-lan: topology change detected, propagating
2021-10-04T15:49:40.897437-05:00Z WBC502 kern.info kernel: [ 219.393344] br-lan: port 2(wifijet1) neighbor 8000.bc:a5:11:7f:0a:4b lost
2021-10-04T15:49:21.097321-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 WPA: WPA/WPA2 authentication successful
2021-10-04T15:49:21.095493-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 WPA: pairwise key handshake completed (RSN)
2021-10-04T15:49:21.023148-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: associated
2021-10-04T15:49:07.648787-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:49:03.602813-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: associated
2021-10-04T15:49:03.591558-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:55.990154-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:51.942471-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: associated
2021-10-04T15:48:51.721508-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:51.301303-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:50.894555-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:48.656219-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0a:4d WPA: WPA/WPA2 authentication successful
2021-10-04T15:48:48.654803-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0a:4d WPA: pairwise key handshake completed (RSN)
2021-10-04T15:48:48.581231-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0a:4d IEEE 802.11: associated
2021-10-04T15:48:48.360898-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0a:4d IEEE 802.11: disassociated
2021-10-04T15:48:33.661997-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 WPA: WPA/WPA2 authentication successful
2021-10-04T15:48:33.660056-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 WPA: pairwise key handshake completed (RSN)
2021-10-04T15:48:32.821898-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: associated
2021-10-04T15:48:32.613243-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: associated
2021-10-04T15:48:32.601436-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:23.525662-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:22.255669-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:21.682032-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
2021-10-04T15:48:21.263239-05:00Z WBC502 daemon.info hostapd: Ham-WiFi-Bridge: STA bc:a5:11:7f:0b:97 IEEE 802.11: disassociated
I also got the info from one of the Satillite logs before i lost contact with it and it had this to say
:50:13.350559-05:00Z WBC502 kern.info kernel: [280321.961129] sysctl (24040): drop_caches: 3
2021-10-04T15:50:12.960158-05:00Z WBC502 user.notice memory: freemem=18752, totalmem=125292, rate=14, Need to free memory caches!!
2021-10-04T15:49:43.274108-05:00Z WBC502 kern.info kernel: [280291.896020] br-lan: topology change detected, propagating
2021-10-04T15:49:43.273697-05:00Z WBC502 kern.info kernel: [280291.890853] br-lan: port 1(ath55) received tcn bpdu
2021-10-04T15:49:42.278788-05:00Z WBC502 kern.info kernel: [280290.903597] br-lan: topology change detected, propagating
2021-10-04T15:49:42.278370-05:00Z WBC502 kern.info kernel: [280290.898435] br-lan: port 1(ath55) received tcn bpdu
2021-10-04T15:49:19.246394-05:00Z WBC502 kern.info kernel: [280267.870563] br-lan: port 1(ath55) entered forwarding state
2021-10-04T15:49:19.245965-05:00Z WBC502 kern.info kernel: [280267.864870] br-lan: topology change detected, propagating
2021-10-04T15:49:04.203620-05:00Z WBC502 kern.info kernel: [280252.824873] br-lan: port 1(ath55) entered learning state
2021-10-04T15:48:57.024923-05:00Z WBC502 user.notice connect: Ham-WiFi-Bridge BC:A5:11:7F:0B:D6 IEEE802.11: associated
2021-10-04T15:48:49.201062-05:00Z WBC502 kern.info kernel: [280237.824738] br-lan: port 1(ath55) entered listening state
2021-10-04T15:48:49.200655-05:00Z WBC502 kern.info kernel: [280237.818981] br-lan: port 1(ath55) entered listening state
2021-10-04T15:48:49.171315-05:00Z WBC502 daemon.notice netifd: Network device 'ath55' link is up
2021-10-04T15:48:49.170861-05:00Z WBC502 kern.info kernel: [280237.793224] br-lan: port 1(ath55) entered disabled state
2021-10-04T15:48:49.170460-05:00Z WBC502 kern.info kernel: [280237.786779] br-lan: port 1(ath55) entered listening state
2021-10-04T15:48:49.170022-05:00Z WBC502 kern.info kernel: [280237.781020] br-lan: port 1(ath55) entered listening state
2021-10-04T15:48:49.148627-05:00Z WBC502 kern.warn kernel: [280237.770009] Number of STA VAPs connected: 1
2021-10-04T15:48:49.147855-05:00Z WBC502 kern.warn kernel: [280237.770009]
2021-10-04T15:48:49.147138-05:00Z WBC502 kern.warn kernel: [280237.763756] Beacon mode set to staggered. Cannot enable FD
2021-10-04T15:48:49.145868-05:00Z WBC502 kern.warn kernel: [280237.759043] send_vdev_up_cmd_non_tlv for vap 0
2021-10-04T15:48:49.145452-05:00Z WBC502 kern.warn kernel: [280237.751601] su bfee 1 mu bfee 1 su bfer 1 mu bfer 0 impl bf 0 sounding dim 1
2021-10-04T15:48:49.144975-05:00Z WBC502 kern.warn kernel: [280237.747385] send_wmm_update_cmd_non_tlv:
2021-10-04T15:48:48.676795-05:00Z WBC502 kern.warn kernel: [280237.299597] send_wmm_update_cmd_non_tlv:
2021-10-04T15:48:48.675951-05:00Z WBC502 kern.warn kernel: [280237.294105] ol_vdev_start_resp_ev for vap 0 (85b64000)
2021-10-04T15:48:48.675400-05:00Z WBC502 kern.warn kernel: [280237.290518] OL vap_start -
2021-10-04T15:48:48.674692-05:00Z WBC502 kern.warn kernel: [280237.287977] VDEV START
2021-10-04T15:48:48.673831-05:00Z WBC502 kern.warn kernel: [280237.285029] OL vap_start +
2021-10-04T15:48:48.672955-05:00Z WBC502 kern.warn kernel: [280237.274894] ieee80211_match_rsn_info[830] pairwise 0x8, gtk 0x8 , keymgmt 0x2
2021-10-04T15:48:48.634118-05:00Z WBC502 kern.warn kernel: [280237.254947] Warning:Stop during VAP Init !
2021-10-04T15:48:48.620231-05:00Z WBC502 kern.warn kernel: [280237.236970] send_wmm_update_cmd_non_tlv:
2021-10-04T15:48:48.619804-05:00Z WBC502 kern.warn kernel: [280237.236942] ol_vdev_start_resp_ev for vap 0 (85b64000)
2021-10-04T15:48:48.619405-05:00Z WBC502 kern.warn kernel: [280237.228369] OL vap_start -
2021-10-04T15:48:48.619007-05:00Z WBC502 kern.warn kernel: [280237.228363] VDEV START
2021-10-04T15:48:48.618610-05:00Z WBC502 kern.warn kernel: [280237.228355] OL vap_start +
2021-10-04T15:48:48.618208-05:00Z WBC502 kern.warn kernel: [280237.220539] ieee80211_match_rsn_info[830] pairwise 0x8, gtk 0x8 , keymgmt 0x2
2021-10-04T15:48:48.617773-05:00Z WBC502 kern.warn kernel: [280237.213357] [ieee80211_ioctl_setmlme] set desired bssid bc:a5:11:7f:0b:d6
2021-10-04T15:48:48.617364-05:00Z WBC502 kern.warn kernel: [280237.205821] DES SSID SET=Ham-WiFi-Bridge
2021-10-04T15:48:48.616930-05:00Z WBC502 kern.warn kernel: [280237.205821]
2021-10-04T15:48:48.616512-05:00Z WBC502 kern.warn kernel: [280237.199350] [DEBUG] vap-0(ath55):set SIOC80211NWID, 15 characters
2021-10-04T15:48:17.946757-05:00Z WBC502 user.warn insight-brokerd[2614]: Device state is offline. Skip collecting monitoring data.
2021-10-04T15:47:55.292680-05:00Z WBC502 user.notice connect: Ham-WiFi-Bridge BC:A5:11:7F:0B:D6 IEEE802.11: disassociated
2021-10-04T15:47:47.945936-05:00Z WBC502 user.warn insight-brokerd[2614]: Device state is offline. Skip collecting monitoring data.
2021-10-04T15:47:47.553912-05:00Z WBC502 kern.info kernel: [280176.177476] br-lan: port 1(ath55) entered disabled state
2021-10-04T15:47:47.553178-05:00Z WBC502 daemon.notice netifd: Network device 'ath55' link is down
2021-10-04T15:47:47.544796-05:00Z WBC502 kern.warn kernel: [280176.165080] STOPPED EVENT for vap 0 (85b64000)
2021-10-04T15:47:44.530277-05:00Z WBC502 user.notice connect: Ham-WiFi-Bridge BC:A5:11:7F:0B:D6 IEEE802.11: associated
2021-10-04T15:47:43.536049-05:00Z WBC502 kern.info kernel: [280172.156881] br-lan: port 1(ath55) entered listening state
2021-10-04T15:47:43.535526-05:00Z WBC502 kern.info kernel: [280172.151086] br-lan: port 1(ath55) entered listening state
2021-10-04T15:47:43.534962-05:00Z WBC502 kern.warn kernel: [280172.139935] Number of STA VAPs connected: 1
2021-10-04T15:47:43.534323-05:00Z WBC502 kern.warn kernel: [280172.139935]
2021-10-04T15:47:43.533787-05:00Z WBC502 daemon.notice netifd: Network device 'ath55' link is up
2021-10-04T15:47:43.533228-05:00Z WBC502 kern.warn kernel: [280172.133656] Beacon mode set to staggered. Cannot enable FD
2021-10-04T15:47:43.518877-05:00Z WBC502 kern.warn kernel: [280172.128946] send_vdev_up_cmd_non_tlv for vap 0
2021-10-04T15:47:43.516084-05:00Z WBC502 kern.warn kernel: [280172.121511] su bfee 1 mu bfee 1 su bfer 1 mu bfer 0 impl bf 0 sounding dim 1
2021-10-04T15:47:43.515534-05:00Z WBC502 kern.warn kernel: [280172.117298] send_wmm_update_cmd_non_tlv:
2021-10-04T15:47:43.255813-05:00Z WBC502 kern.warn kernel: [280171.879478] send_wmm_update_cmd_non_tlv:
2021-10-04T15:47:43.255285-05:00Z WBC502 kern.warn kernel: [280171.874014] ol_vdev_start_resp_ev for vap 0 (85b64000)
2021-10-04T15:47:43.254752-05:00Z WBC502 kern.warn kernel: [280171.870513] OL vap_start -
2021-10-04T15:47:43.254159-05:00Z WBC502 kern.warn kernel: [280171.867980] VDEV START
2021-10-04T15:47:43.253582-05:00Z WBC502 kern.warn kernel: [280171.865061] OL vap_start +
2021-10-04T15:47:43.252485-05:00Z WBC502 kern.warn kernel: [280171.854914] ieee80211_match_rsn_info[830] pairwise 0x8, gtk 0x8 , keymgmt 0x2
2021-10-04T15:47:43.222644-05:00Z WBC502 kern.warn kernel: [280171.844218] STOPPED EVENT for vap 0 (85b64000)
2021-10-04T15:47:43.222095-05:00Z WBC502 kern.warn kernel: [280171.840175] Unable to process RX info
2021-10-04T15:47:43.221570-05:00Z WBC502 kern.warn kernel: [280171.833946] Beacon mode set to staggered. Cannot enable FD
2021-10-04T15:47:43.221041-05:00Z WBC502 kern.warn kernel: [280171.829230] send_vdev_up_cmd_non_tlv for vap 0
2021-10-04T15:47:43.220500-05:00Z WBC502 kern.warn kernel: [280171.821781] su bfee 1 mu bfee 1 su bfer 1 mu bfer 0 impl bf 0 sounding dim 1
2021-10-04T15:47:43.219865-05:00Z WBC502 kern.warn kernel: [280171.817558] send_wmm_update_cmd_non_tlv:
2021-10-04T15:47:43.219335-05:00Z WBC502 kern.warn kernel: [280171.795850] send_wmm_update_cmd_non_tlv:
2021-10-04T15:47:43.218808-05:00Z WBC502 kern.warn kernel: [280171.795825] ol_vdev_start_resp_ev for vap 0 (85b64000)
2021-10-04T15:47:43.218245-05:00Z WBC502 kern.warn kernel: [280171.787344] OL vap_start -
2021-10-04T15:47:43.185427-05:00Z WBC502 kern.warn kernel: [280171.787339] VDEV START
2021-10-04T15:47:43.185031-05:00Z WBC502 kern.warn kernel: [280171.787331] OL vap_start +
2021-10-04T15:47:43.184623-05:00Z WBC502 kern.warn kernel: [280171.779553] ieee80211_match_rsn_info[830] pairwise 0x8, gtk 0x8 , keymgmt 0x2
2021-10-04T15:47:43.184216-05:00Z WBC502 kern.warn kernel: [280171.772370] [ieee80211_ioctl_setmlme] set desired bssid bc:a5:11:7f:0b:d6
2021-10-04T15:47:43.139205-05:00Z WBC502 kern.warn kernel: [280171.763241] DES SSID SET=Ham-WiFi-Bridge
2021-10-04T15:47:43.138805-05:00Z WBC502 kern.warn kernel: [280171.763241]
2021-10-04T15:47:43.138401-05:00Z WBC502 kern.warn kernel: [280171.756710] [DEBUG] vap-0(ath55):set SIOC80211NWID, 15 characters
2021-10-04T15:47:23.545303-05:00Z WBC502 user.notice connect: Ham-WiFi-Bridge BC:A5:11:7F:0B:D6 IEEE802.11: disassociated
2021-10-04T15:47:17.945409-05:00Z WBC502 user.warn insight-brokerd[2614]: Device state is offline. Skip collecting monitoring data.
2021-10-04T15:47:15.975446-05:00Z WBC502 kern.info kernel: [280144.597458] br-lan: port 1(ath55) entered disabled state
2021-10-04T15:47:15.973092-05:00Z WBC502 daemon.notice netifd: Network device 'ath55' link is down
2021-10-04T15:47:15.964831-05:00Z WBC502 kern.warn kernel: [280144.585166] STOPPED EVENT for vap 0 (85b64000)
2021-10-04T15:47:12.714722-05:00Z WBC502 user.notice connect: Ham-WiFi-Bridge BC:A5:11:7F:0B:D6 IEEE802.11: associated
2021-10-04T15:47:11.777402-05:00Z WBC502 kern.info kernel: [280140.396753] br-lan: port 1(ath55) entered listening state
2021-10-04T15:47:11.776723-05:00Z WBC502 kern.info kernel: [280140.390980] br-lan: port 1(ath55) entered listening state
2021-10-04T15:47:11.775262-05:00Z WBC502 kern.warn kernel: [280140.380017] Number of STA VAPs connected: 1
2021-10-04T15:47:11.774602-05:00Z WBC502 kern.warn kernel: [280140.380017]
2021-10-04T15:47:11.773858-05:00Z WBC502 kern.warn kernel: [280140.373783] Beacon mode set to staggered. Cannot enable FD
2021-10-04T15:47:11.772816-05:00Z WBC502 kern.warn kernel: [280140.369068] send_vdev_up_cmd_non_tlv for vap 0
2021-10-04T15:47:11.758810-05:00Z WBC502 daemon.notice netifd: Network device 'ath55' link is up
2021-10-04T15:47:11.755428-05:00Z WBC502 kern.warn kernel: [280140.361621] su bfee 1 mu bfee 1 su bfer 1 mu bfer 0 impl bf 0 sounding dim 1
2021-10-04T15:47:11.755019-05:00Z WBC502 kern.warn kernel: [280140.357405] send_wmm_update_cmd_non_tlv:
2021-10-04T15:47:11.285717-05:00Z WBC502 kern.warn kernel: [280139.909381] send_wmm_update_cmd_non_tlv:
2021-10-04T15:47:11.285197-05:00Z WBC502 kern.warn kernel: [280139.903873] ol_vdev_start_resp_ev for vap 0 (85b64000)
2021-10-04T15:47:11.284673-05:00Z WBC502 kern.warn kernel: [280139.900481] OL vap_start -
2021-10-04T15:47:11.284101-05:00Z WBC502 kern.warn kernel: [280139.897947] VDEV START
2021-10-04T15:47:11.282914-05:00Z WBC502 kern.warn kernel: [280139.895030] OL vap_start +
2021-10-04T15:47:11.282420-05:00Z WBC502 kern.warn kernel: [280139.884894] ieee80211_match_rsn_info[830] pairwise 0x8, gtk 0x8 , keymgmt 0x2
2021-10-04T15:47:11.241852-05:00Z WBC502 kern.warn kernel: [280139.864942] Warning:Stop during VAP Init !
2021-10-04T15:47:11.241455-05:00Z WBC502 kern.warn kernel: [280139.854746] send_wmm_update_cmd_non_tlv:
2021-10-04T15:47:11.241062-05:00Z WBC502 kern.warn kernel: [280139.854720] ol_vdev_start_resp_ev for vap 0 (85b64000)
2021-10-04T15:47:11.240661-05:00Z WBC502 kern.warn kernel: [280139.846194] OL vap_start -
2021-10-04T15:47:11.240262-05:00Z WBC502 kern.warn kernel: [280139.846189] VDEV START
2021-10-04T15:47:11.239826-05:00Z WBC502 kern.warn kernel: [280139.846180] OL vap_start +
2021-10-04T15:47:11.239431-05:00Z WBC502 kern.warn kernel: [280139.838374] ieee80211_match_rsn_info[830] pairwise 0x8, gtk 0x8 , keymgmt 0x2
2021-10-04T15:47:11.239023-05:00Z WBC502 kern.warn kernel: [280139.831194] [ieee80211_ioctl_setmlme] set desired bssid bc:a5:11:7f:0b:d6
2021-10-04T15:47:11.198302-05:00Z WBC502 kern.warn kernel: [280139.822474] DES SSID SET=Ham-WiFi-Bridge
2021-10-04T15:47:11.197877-05:00Z WBC502 kern.warn kernel: [280139.822474]
2021-10-04T15:47:11.197470-05:00Z WBC502 kern.warn kernel: [280139.816071] [DEBUG] vap-0(ath55):set SIOC80211NWID, 15 characters
2021-10-04T15:47:00.086626-05:00Z WBC502 daemon.notice netifd: Network device 'ath55' link is down
2021-10-04T15:47:00.084871-05:00Z WBC502 kern.warn kernel: [280128.705081] STOPPED EVENT for vap 0 (85b64000)
2021-10-04T15:46:55.973700-05:00Z WBC502 kern.info kernel: [280124.590275] br-lan: port 1(ath55) entered disabled state
2021-10-04T15:46:55.971732-05:00Z WBC502 daemon.notice netifd: Network device 'ath55' link is up
2021-10-04T15:46:55.971197-05:00Z WBC502 kern.info kernel: [280124.583660] br-lan: port 1(ath55) entered listening state
2021-10-04T15:46:55.970661-05:00Z WBC502 kern.info kernel: [280124.577928] br-lan: port 1(ath55) entered listening state
2021-10-04T15:46:55.970099-05:00Z WBC502 kern.warn kernel: [280124.571169] Number of STA VAPs connected: 1
2021-10-04T15:46:55.969568-05:00Z WBC502 kern.warn kernel: [280124.571169]
I noticed a few things there - namely the memory notices and also all the messages about bpdus.
A long time ago I had some Cisco point to point Aironets and i remember Bridge Packet Datagram Units causing the interfaces to just shut off on me sometimes.
Anyway I have no idea what to do at this point ANY help is appreciated.
No RepliesBe the first to reply
