Retired_Member
Mar 21, 2020SRR60 loses settings when power cycled
2020-03-21 08:29 PM
1-ongoing issues with dropped internet connection
2-ongoing issues with wifi dropping from devices
3-moving my router srr60 to a new location because of some remodeling work. now seeing each time I cycle power (working on wiring in new location) the router doesnt remember me...or any of it's settings. it's starting over.
4-in redoing settings, it's a real pain in the ass that each wifi setting needs a long reboot. can we not have something that lets you make all changes and then apply in one reboot?
very unhappy right now with the hardware as well as the software tools to troubleshoot it.
version 2.5.0.108
backed up one cause the newer one doesnt show all devices connecting, which is a real issue in troubleshooting.
ugh!
Model: SRK60B03|Orbi Pro Tri-Band Business WiFi System
- Retired_MemberMar 29, 2020
Problem Solved!
Orbi replaced with another brand system thats simple IT that just works.
Anyone want a base station and two satellites?
Best of luck all.
- Retired_Member
is this recommended because it's a default response: "run latest firmware" or because this firmware has a specific solution to any or all of my issues? becuase I know it has another problem, which is why I backed up one.
also note: I went to latest firmware in effort to improve connectivity issues, but lost ability to see connected devices.
- RaghuHRNETGEAR Expert
Hi Retired_Member
Could please confirm your original issues are resolved or not after the firmware update to FW 2.5.1.106? I see you are not seeing the devices in the attached device list page. List out any other issues with debug logs. Hope you have upgraded your SRS60 if any.
How to take debug logs:
1. Go to https://<Orbi Pro IP address>/debug.htm
2. Click on start capture.
3. Wait for the issue to happend before saving. ( give at least 5 min before savig debug logs)
You can upload debug logs into google drive or something similar and send me link via PM.
Thanks,
Raghu
- Retired_Member
Problem Solved!
Best of luck all.
