downsc
Apr 01, 2019Initiate
How to disable / deactivate Armor on RBR50?
Hey team,
I've enabled Armor on my Orbi RBR50 but decided I no longer wish to use it, is there a way to remove it without needing to factory reset the entire device
I would post this here and ask.
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Possibly might have to reset...
downsc wrote:
Hey team,
Found it...
I'm using the iOS app, and here's where it's at...
When you're logged in, you're on the page with the big icons (you'll see the Armor Security icon as "Activated")
Now click the HOME icon on the top left.
Click SETTINGS
You should see a menu with Router Settings, Wifi Settings, etc
From the list, select SECURITY
Now you should see a toggle switch to turn OFF the Netgear Armor.
Even though the main icon will still say ACTIVE, it will be off. If you open the orbilogon.com page on your computer, you'll see it's off.
Also can find out on the Armor forum as well:
https://www.netgear.com/landings/armor- danny07Tutor
I searched there and did not find the answer. I did see posts in the Armor forum with the same question, and you replying that people should look in the Armor forum. Muy helpful.
Google brought me to the answer above.
Thanks for letting us know. :smileywink:
- SouthyTutor
This is NOT a fix. Despite it being toggled to "off" it is very much still on and hobbling my use of sites. It completely blocks the use of the App Store on ipad. I can no longer download any apps without first disconnecting from the Orbi mesh and connecting to a wifi hotspot on my android phone. I will box this damned thing up tomorrow if a fix can't be offered. How can a company be so bloody negligent, shafting its customers with what amounts to little more than malware. Unable to use Tidal on Sonos, unable to download apps on Apple, unable to access perfectly safe sites unless I switch to a wifi hotspot. Netgear, are you having a laugh?
I can't disable Armor... When I toggle the switch in the app, I there is a "Disabling NETGEAR Armor." screen which appears for a period of time witht he swirly icon indicating waiting for something to occur. Then an error message "Process is taking too long (more than 60 secs), Try again!" or "Sorry, the action was failed. Please try again."
So how can I get rid of this crap which is killing my internet performance? I've tried this at least 50 times, can't get past the error messages.
iOS app version 2.4.21.5 ... Firmware 2.5.1.8
Hi BWest1 -- unfortunately, you probably need to do a reset of your router.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000053863/I-reset-my-Orbi-router-how-do-I-set-it-up-again
(The above aren't the clearest, but they should get you in the right direction.)
Just whatever you do, do NOT re-enable Armor (Bitdefender in NETGEAR clothing).
BWest1 wrote:I can't disable Armor... When I toggle the switch in the app, I there is a "Disabling NETGEAR Armor." screen which appears for a period of time witht he swirly icon indicating waiting for something to occur. Then an error message "Process is taking too long (more than 60 secs), Try again!" or "Sorry, the action was failed. Please try again."
- DKJTutor
I am also having an issue with many sites being blocked. The directions to disable Netgear Armor are easy to follow, unfortunately the slider does not unblock sites. Before I return this product that I just bought, can someone post instructions on how to disable Armor, this would likely help reduce your call volumns.
- MountainmanwvInitiateHave the same issue. In any disable mergers armor. When I slide to turn off I get error process taking to long over 60 sec. need this fixed. As my internet keeps disconnecting.
