mgcblossom
Mar 29, 2026Guide
ORBI application issue
First ORBI system was active on the ORBI application, was able to view all details. We purchased a second system for a Delaware location; application dropped our first, although picked up our second. We are unable to view details for our first location. Systems are on different routers, one verizon one xfinity. Looking for a solution or how to add back our first location.
Many thanks to all the participants for your cooperation and suggestions to resolve my issue.
I set up my first ORBI system in December, in March I set up my second ORBI system which started my application issues. Prior to adding my second ORBI system I did inquiry of ORBI if a second system would cause issues with my first system, representative indicated no, which did not ring true.
Setting up my second system I did not realize the ORBI automatically activated the "any where access" this was my issue. Returning to the second system location ORBI tech walked me thru how to disable "any where access" which allowed the ORBI application to show both systems. My hope is future inquires with this issue will benefit from my system resolution. I have requested ORBI leave the case open for two days to endure my resolve is permanent.
Appreciate all the assistance, with the 2nd ORBI system, we did use the application option (set up a new orbi system). Seems the application only recognizing the last system installed.
You may need to get to the other system and connect your mobile device there. While there disable AA then re-enable it. I have noticed this when having two systems online, that one of them doesn't get fully accessible until you do this odd routine. I Just put a different Orib system online, Orbi app only sees the prior one that was removed so I'll have to get the phone re-connnected to the new system locally, then cycle AA off then back ON. Will get access then.
What I believe is supposed to happen is this:
- The user has one Orbi system defined in the Orbi app.
- The user gets another Orbi system and uses the existing Orbi app to configure it by selecting this menu item:
When the new system is configured, it appears at the top of the menu page under the first system. When the user opens the Orbi app, either system can be selected from the menu at the top of the page. As far as I am aware, there is no practical limit to the number of Orbi systems that can be managed using one Orbi app.
(This is why I asked if the same Orbi app on the same smartphone was used to set up the second Orbi system as was used to set up the first system.)
Since the app that is currently being used appears to have only one Orbi system, that is all it knows about.
Application -2.51.0.5242
RBE 371
V- 12.1.3.11
Given my issue with the application only showing one system, how would I be able to view details of my other system. Thanks
So you have two 370 series systems?
Yes, RBE370 for New Jersey, RBE370 for Delaware currently only the Delaware location is visible on the ORBI application. My concern is not being able to check on the New Jersey system while also having the ability to view Delaware.
Thanks
What mobile platform are you using for Orbi app?
What version of Orbi app are you using?
What model# Orbi systems do you have?
What FW version is loaded on the Orbi systems?
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
ORBI application did display first system with all details, when second system set up first location system was dropped. ORBI application does not indicate/show a second location. I am unable to determine any issues without access to the second file. I did call Netgear to verify a second system would not impact my original. Technician advised all would be OK, NOT SO since I am missing my original set up
- HappyCatApprentice
The same device (smartphone, tablet) running the Orbi app was used to set up the new the new system?
From all I have read, one app can control any number of separate Orbi systems (although it is not always obvious which system is which on the list).
