Jul 13, 2021Guru - Experienced User
New - RBK752/753 Firmware Version 4.6.3.7 Released
Security Fixes:
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
New Features and Enhancements:
- Supports Smart Parental Controls (SPC) :smileysurprised:
- Supports 4-digit firmware update
- Removes the remote management feature from the router web interface (if disabled at time of update) to improve router security. :smileysurprised:
Bug Fixes:
- Fixes the DNS timeout issue :smileywink:
- Fixes the issue where a phantom satellite appears in device list
- Various other bug fixes
Download Link:
RBR750 - https://www.downloads.netgear.com/files/GDC/RBK752/RBR750-V4.6.3.7_2.0.49.zip
RBS750 - https://www.downloads.netgear.com/files/GDC/RBK752/RBS750-V4.6.3.7_2.0.49.zip
For Smart Parent Controls support, help and information, please post in the following forum:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
This article applies to:
RBK752
RBK753
RBK753S
RBK754
RBR750
RBS750
Let us know how it works for you.
***Updated: 9/13/2021 11:50 AM PT
Hello Orbi Community,
Please accept my apologies for any delay in getting this message to you. I have been advised that an official firmware release is in the final stages of internal testing and in the process of being posted to our support site. Likely, within the next 24 hours.
To get this firmware release now please click the link below:
For instructions on how to manually download this firmware please visit:
How do I manually upgrade firmware on my Orbi router using orbilogin.com?
Thank you for your patience,
ChristineT
I just factory reset everything as i had to do something. Why is it that during the setup the router seems to already know my custom sattelite names? (also not had to sync them again).I have not restored anything and reset all 4 devices with a paperclip until the blinking orange light... btw. The disconnects are already happening again. No i have not contacted support yet.
Please open up a support ticket and contact NG support and let them know what your experinecing.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto?
Berryvl wrote:I just factory reset everything as i had to do something. Why is it that during the setup the router seems to already know my custom sattelite names? I have not restored anything and reset all 4 devices with a paperclip until the blinking orange light... btw. The disconnects are already happening again. No i have not contacted support yet.
FURRYe38 wrote:Please open up a support ticket and contact NG support and let them know what your experinecing.
Really?
Its not that i am not willing but it seems my complementary support expired in april, but i can get a hw replacement.
My hw is not defected, my sattelites are placed correctly and the frequency were never an issue. The issues i see now started directly after upgrading to 4.6.3.7 the day before (and months) everything worked really perfectly. minutes after upgrading the disconnects and instability started to happen.So all the questions asked above are not relevant as with 3.2.18.1 everything was fine and so far i was really happy with NG and the Orbi's, recommended it to friends, colleages and family.. but i am starting to feel sorry for that.
I think NG has to acknowledge there are issues with the 4.6.3.7 version and fix it as soon as possible instead of stringing everyone along to open support tickets.
At this moment my household is disrupted becaues of this. Already spent hours trying to fix it myself. This is not what I was buying into when i orderd the RBK753. Of course bugs exist but this feels as if SQA failed and 4.6.3.7 was not properly tested before the release.
So rather than asking everyone to open tickets, please look into it yourself, it is unimaginable that NG is unable to reproduce these issues withing Support/Engineering.
Instead of trying the reset button, try using the ERASE function on the RBRs web page. Under Advanced Tab/Advanced settings/Backup. See if this clears out all of yoru configurations from the RBR.
Be sure to also clear out all browser caches after you trigger the ERASE.
Berryvl wrote:I just factory reset everything as i had to do something. Why is it that during the setup the router seems to already know my custom sattelite names? (also not had to sync them again).I have not restored anything and reset all 4 devices with a paperclip until the blinking orange light... btw. The disconnects are already happening again. No i have not contacted support yet.
- I have disabled the AX feature for 2.4 and 5 GHz and the problem seems to be gone….
Experiencing all these issues also with my RBR750 and RBS750. I tried to roll back the satalite to previous firmware version and it worked but automatically updated with my consent. I wish I could return this but out of my window.
I have tried the following:
- Trying this twice - Factory resetting both the RBR750 and RBS750
- Rolling back the RBS750 to previous firmware version
- Disabling RTS, reducing power tx percentage, expanding the distance (and shrinking) between RBR750 and RBS750
Issues Experiencing:
- DNS issues (internet goes down) have to reboot router but modem is fine
- RBS750 looses connection and repeats blue light throught the day but does not display a light that it lost connection
- Slow WIFI performance about 200-300 mbps compared to last firmware release using the orbi app measurement tools
Try disabling AX mode on both radios?
Trying that now and seeing if there is a difference. Will report back after 2-3 days.
In meantime, has ANYONE in this thread attempted to down grade from v4 to v3 and was it successful?
Seeing some post saying they've been able to down grade.
Try to find out which v3 versions they used and what browser...
- Gatorade2000ApprenticeYou can downgrade satellite but not the main router. There is no fking “yes” button to proceed.
Gatorade2000 wrote:
You can downgrade satellite but not the main router. There is no fking “yes” button to proceed.I have also downgraded the satellite to the v3 firmware only to find out it upgraded itself the next day. There is no way to "disable" the updates to my knowledge. I have tried blocking the updates domains though through my custom DNS service (AdGuardHome). I wish there was a feature like Windows at least to disable any major updates (i.e. v3 to v4) for 90 days so the bugs can be worked out.
Myabe someone can ask this person what they did to downgrade theres:
Seems to mention they got there RBR downgraded prior to downgrading the RBS.
Waiting to see what browser they used and the process. I presume they used the RBRs web page then used the RBS web page to downgrade them lastly. Hopefully they can confirm.
- mnkknmInitiateI patiently waited a week for a fix for the Orbi. Since the firmware “upgrade”. My WiFi is almost unusable with satellites working/not working, having to jump to guest WiFi and back to the main WiFi as one or both would intermittently stop working. I have factory reset daily and all of my home automation is next to useless. I can’t wait any longer. Any recommendations for another WiFi 6 mesh brand? Costco has a lot of choices right now. Range over speed is my priority. Thanks in advance .
You'll need to return the system then and find something else. Rencommend other NG routers if they have anything. If not. Good luck else where.
- LiquidPTutor
I have a RBK753 purchased from COSTOC.
Now it runs on V4.6.3.7_2.0.49 on all 3 units (One RBR750, two RBS750). I could not find SPC in either the Orbi mobile app, or the web UI.
I did a factory reset on the entire kit last night, uninstall/reinstall Orbi app on my android phone, clean up the storage/cache on my android phone, install Orbi app on my wife's iPhone. It does not offer me with SPC.
Anyone know what else trick I should try, or help me debug this issue. Your input is appreciated.
Thanks!
Try this:
https://kb.netgear.com/000062852/How-do-I-upgrade-from-Circle-to-NETGEAR-Smart-Parental-Controls
Please post about any SPC help or need information here in the SPC forumL
Thank you.
Thanks!
- LiquidPTutor
Sure. let me post there as well.
I tried the link, there is no "Add On" being offered to my orbi mobile app.
- GtjacketTutor
Has anyone gotten any communications from the official NG support? Did they ask for any logs, provide any updates, acknowledge the issue with the satellite instability? I disabled AX features (without going through factory reset) and it seemed to actually make things worse. Trying to avoid time spent on all this workaround when clearly it is a bug in the firmware that needs to be fixed.
NG is aware of problems with the FW. They don't give time frames on when new fixes will be forth coming.
Try a factory reset and setup from scratch.
Some other posters said they got better operation with AX mode disabled, so it may work so some, may not for others.
- scobooGuide
Hello,
We have Cox GigaBlast service (1 GB of bandwidth).
When FW4.6.3.7 was released, our router auto-update and our speed went from 940mbps to 600mbps (using Internet Speed Test on Orbi app) to 8mbps-22mbps using SpeedTest.net on MacBookPro and other wireless devices connected to the Orbi Router. Our TV is wired and is getting 78mbps.
I 'upgraded' from the RBK 750 to the RBK753S. When I first installed this 'new' router with firmware 3.1.18.1, we got accurate speed and the wifi did not drop. But Netgear removed the option to select whether to auto-upgrade f/w...which means our f/w auto-upgraded to 4.6.3.7!! So now we're back to the exact same problem!
Cox is our ISP. They have sent three technicians to our home to verify the signal to the pedestal and to the node for our house; to the external box on our house and directly to the Netgear CM1200 modem. It is NOT an ISP issue.
Any solutions? The agent I spoke with today at Netgear is escalating this issue to a senior technical lead, as it's been three weeks of speed between 8mbps and 200mbps.
Thanks
Scott- FURRYe38Guru - Experienced User
scoboo wrote:
Hello,
Thanks
Scott - Gatorade2000Apprenticescott, good morning. All these 10 pages or so are about the same issue.
- remsreefGuide
I confirm post #235 fixed the issue for me. It was a DHCP issue the entire time! No more disconnects and I have my Orbi back, thank you!
1. I ended up turning off the AX channels, although I don't really think this led to an increase in stability.
2. I am running the 2437 CTX/RTX?
- ahswpApprentice
Sorry , I'm confused, can you walk me through what you did here? My connection to my sattalites have been HORRIBLE and constantly dropping.
I have Verizon FIOS and an ONT. My Orbi has always been 192.168.1.1 and all the devices 192.168.1.X
What did you changed that fixed it?
Thank you!
- How are we weeks later and no fix or roll back options?
Mistakes happen, I get that. The sign of a company is how the deal with it. Netgear approach? Silence. I’m shocked and appalled. Let us roll back is such a simple solution in the short term.
We’re in the middle of a pandemic. People are trying to work from home, and home school - our £700 routers should be able to enable that.
Totally unacceptable.- Gatorade2000Apprenticebuy their premium warranty and pay $$ more. I am also surprised that NG can get away with just 90 day support. I have filed a complaint with my state AG about this.
- Same here. I actually did pay for the extended warranty but have found out that there is no way for me to call support? How can I request or file a warranty replacement without calling?
I’m reaching out to my legal service to see if I can get a buy back going.
You guys can try this:
FW fixes don't happen over night.
Totally unacceptable.- Gatorade2000Apprenticeuncle, first it is more than overnight. second this wasnt a hardware problem.
Totally unacceptable.So I was contacted by support and gave them some debug logs (contacted on 8/20). I also gave them some more over the weekend. Based on our conversation, they are still collecting data to troubleshoot the issue. I am also very fustrated that these expensive routers can be crippled by a non-voluntary firmware update (also complained about this to them). I come from an embedded software background (been doing it for over decade). I offered to speak with one of their software engineers directly to help troubleshoot the issue engineer to engineer.
Since this is such a widespread issue, I do wish that officals from NG could post on this forum updates weekly (sticky thread). I have a Rachio sprinkler controller and the Homekit was buggy due to a firmware update. They are posting updates (even if there is nothing to report) for some communication to their customers. I would implor NG to do the same.
So I am noticing although I have disabled the AX features, my RBS750 still disconnects once a day (blue light and devices disappear). The network is definitely not stable. I was looking over the posts about a DHCP issue but not understanding how it applies to me with a Netgear modem from Comcast to RBR750. I do have my DHCP giving out IP address from 192.168.1.X to 192.168.1.Y so I can assign static IP addresses after 192.168.1.Y.
- raven_auVirtuoso
wjbridge wrote:So I am noticing although I have disabled the AX features, my RBS750 still disconnects once a day (blue light and devices disappear). The network is definitely not stable. I was looking over the posts about a DHCP issue but not understanding how it applies to me with a Netgear modem from Comcast to RBR750. I do have my DHCP giving out IP address from 192.168.1.X to 192.168.1.Y so I can assign static IP addresses after 192.168.1.Y.
Think of what might happen if the router DHCP server is very slow or stops giving out IP addresses (which has caused a lot of trouble for me). It looks to me like clients disconnect and try again, and the Satellites get their IP addresses refreshed after a time just like any DHCP client.
