DeaneHornsby
Nov 03, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end)
I followed all the suggested setting changes including:
Disable Guest network
Wireless Settings: 2.4Ghz Channel to 01
Wireless Settings: 5Ghz Channel to 48
Disable SIP ALG on (set to open)
Advance Wireless Settings: enable WMM (2.4Ghz) 2347 (Short Preample/50%)
Advance Wireless Settings: enable WMM (5.0Ghz) 2347 (Short Preample/100%)
IPV6 - Get Automatically from ISP ( I can't see how to turn off other that use a DNS Server)
IP Adddress Assignemtn - Auto Config
Traffic Meter is enabled with traffic volume contro by no limit
My internet speed seems fine 109 Mbps download /40Mbps upload - backhaul status reports as good
I'm using a Mac for Zoom which is wireless connnected to the RBR850 router, and have tried both wirelessly connecting and wired connected to the satellite.
The same lag and still the warning exists.
The firmware i old V4.6.9.11, so that is next up.
Just wondered if you or anyone else had resolved or have a recommended firmware version that work without disrupting all else?
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
I have to say you gurus are super helpful. I was messing about for a while with this and finally found this forum. I didn't know if anyone would respond, but you did and I'm grateful for that.
I'm glad we could help.
If this still happens after you update the firmware, then it would be good to know
- Whether you are connecting to work-related zoom conferences, or whether these are personal. Some companies host their own Zoom servers, and it would be good to know if that is a possibility here.
- Your ISP and internet connection type (fiber, cable, satellite,mobile broadband). Some ISPs will dynamically adjust your upload and download speeds, and that could also explain what you are seeing.
I'll try the firmware update next - after following a few of the suggestions - especially the VPN as this is work related - Zoom is a work app not personal.
ISP is Optus - NBN which is via Hybrid Fibre-Coaxial (HFC nbn). The nbn connetion box - Network Termination Device (Arris CM8200) - is owned by our National Broadband Network and specific to my apartment's address, so I connect the Orbi RBR into the NTD via its WAN connection.
Before updating:
Same happens with Traffic Meter disabled?
Disable IPv6 on the RBR and test Zoom?
Enable SIP ALG and test?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices connected to the RBR?DeaneHornsby wrote:
Just wondered if you or anyone else had resolved or have a recommended firmware version that work without disrupting all else?- StephenBGuru - Experienced User
FYI, Zoom calls from the Zoom App and web browser don't use SIP. Which appears to be the case here (connecting from a Mac).
But if DeaneHornsby is dialing in from a SIP device, then this test would be useful.
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac, not dialing from a SIP devlice
There is newer firmware:
https://kb.netgear.com/000066592
As an observation, people seem less interested in diagnosing problems with older firmware versions.
Thanks CrimpOn, the corporate VPN was the culprit. I'm going to update the firmware anyhow as per your advise as it old. Relatively new to Orbi I'd been using update firmware which was reporting I had the latest, not realising it was the latest for that Orbi release. I'm now working through the process and correct squence of manual updating the firmware.
As an observation, people seem less interested in diagnosing problems with older firmware versions.I'd also start by updating the firmware.
Does the problem happen only on wifi? Or is this also an issue with ethernet?
