TOPS119's avatar
TOPS119
Luminary
Jul 22, 2026
My RBR has ridiculous ping after 12. update
Has this happen to anybody else where the ping is so high on the rbr but the satellites have the correct ping ? my speed test is terrible on the main router but on the satellites its ok, this happens after the new update.
  • So after multiple days with the orbi team my issue of the router giving slow wrong speeds has been fix with this new update I am going to continue watching to see if anything else was broken in the process but I can confirm now that this new firmware fix that particular wifi issue.
  • Update so after working with Netgear on the issue they change the channel to 2.4ghz 11 and the 5ghz 44 this seems to fix the issue on the Mac book. where in I notice the Mac book start connecting and giving the correct speed but I notice it never fix the issue on the google pixel 10 pro xl. the same speed issue is happening on the phone, this is really confusing.
  • Modem Model - ip3 442m-L/us
    Isp ---flow
    Region - Caribbean
    Connected - mac
    Channel - not sure default
    • FURRYe38's avatar
      NG implemented AUTO channelization on these routers on v12 FW I believe, especially on 5Ghz which had not supported Auto settings for 5Ghz. It did for 2.4Ghz.
      I've always used manual channels on my systems due to nieghboring wifi signals and keep them from interfering. Channels 1 and 40 here. And sometimes the Auto channelization routine doesn't pick what channels should be used on 2.4Ghz which are primary channels of 1, 6 or 11, or 13 outside of the NA region.
      I have not seen any issues with my Mac Book Pro 2018 on these systems using the above configuration.
      Reason for asking about region is that NG has separate regional FW support for these units. NA has specific policies vs EU and all other regions. NG released a NA ONLY regional FW update. While the other regions, FW is still being tested and hoping for next release will be for ALL Regions. Will check to see if your region will be included in the NA region or otherwise.
      Where did you purchase the system from?
      Glad NG support helped with this one item.
  • Test was done same issue everything now connects to the RBR but the wifi signal is strong but gives off very poor reading
    • FURRYe38's avatar
      There a model # of the sercom modem?
      Which ISP are you connected with?
      What region are you located?
      Brand and model# wifi device your connecting to the RBR?
      What channels are you using on the RBR?
  • StephenB's avatar
    TOPS119​ - are you still looking for advice here?
    While I get the frustration with being asked seemingly irrelevant questions, you should at least let us know what troubleshooting steps you've already tried.
    • TOPS119's avatar
      TOPS119
      Luminary
      No disrespect but I've wrote all of them in previous post above. But let's say it again.
      1 I have reset the RBR
      2 I have loaded over the firmware
      3 I have turned off all additions like armour
      • StephenB's avatar
        Thx.  Have you tried a test with the RBS all turned off - just to ensure that your device was connected to the RBR?
    • FURRYe38's avatar
      Seems to be getting to spec speeds with Orbi app thru the RBR...
      • HappyCat's avatar
        HappyCat
        Luminary
        Thanks for taking the time to record and post the Speed Test results from the router.  This does seem to indicate that the issue is related to the WiFi connection of this specific device.
        Some cell phones report the "Link Rate" of their WiFi connection.  The Orbi 'app' Device Manager also reports it.
  • FURRYe38's avatar
    How are you testing pings? Ethernet or wireless?
    What pings values are you seeing?
    How many devices are connected to the system in total?
    • TOPS119's avatar
      TOPS119
      Luminary
      So I have 1gb up and down and this is what I get I have less than 40connected use to work fine before the update. I did a reset of the router same thing.
      • FURRYe38's avatar
        Is this tested on a ethernet PC or wireless?
        What brand and model# ISP modem or ONT is the RBR connected too?
        Is IPv6 enabled?
        Any features enabled like Armor or SPC?
        What is CAT# LAN cable between the RBR and ISP modem/ONT?
        Same thing seen with ethernet PC directly connected to the ISP modem/ONT?
