nickambrose
Aug 16, 2015Tutor
EX6200 drops 2.4GHZ connection every day or so
For some reason my EX6200 drops the 2.4GHZ connection every day or so. The 5GHZ is fine and both my 2.4 and 5GHZ connections on the router are fine.
Rebooting fixes the issue for another day or so.
I have the latest firmware: V1.0.1.60_1.1.98
- nhannNETGEAR Employee Retired
Hi nickambrose,
Which router are you connected to with the EX6200? Please try changing the WiFi channel and updating your router.
http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-changing-channelLet us know how it works for you.
NhanN
I will try it. I really dont think that I should have to pay for a tool after spending $120 on hardware! You should at least provide a tool for me to use!
Thankfully I found a free one and will try channel #1 as it only had 2 users
Hi nickambrose,
Please note that you are also able to view WiFi networks through the NETGEAR genie desktop app.
The software linked previously gives much more detail on the connections than the genie screen below.
NhanN
- MetzgerGuide
Thank Heavens - I thought I was going crazy. I've had my EX6200 for about a week, and I'm having exactly the same issue. I'm in a chat with Netgear support now... they seem to be thinking I should reflash the firmware, but I seriously doubt that's going to help.
Welcome (or commiserations?) to the club.
They didnt even seem to print the serial no on my extender so I wasn't even able to register my product to call in!
I am trying to change the Wifi channel on my router but I dont know why that should help (no other 2G network has a problem)
Will update when I get a chance.
I have latest firmware but did not "reflash"
- Babylon5NETGEAR Employee RetiredA blank serial number usually suggests that the unit is a refurbishment; did you purchase it from a reputable dealer? Is there any pattern to the failure, for example always around the same time of day, when streaming video, when there are many network users?
Did we get a reply from NETGEAR on this issue.???
I have updated to latest firmware, and still the 2.4Ghz drops every few days.
It is bloody annoying
I am going to take it back and get my money back. I hate it when they burry their heads and hope it goes away, READ you forums, ths is not a isolated issue NETGEAR...
Yeah it sucks that they wont even acknowledge but I guess thats the way of it.
I found that going to Fastlane with 5GHZ extender -> Router and 2GZ device -> Extender seems to have it stable for now.
I still get periods of time when internet stops working for 10-30 seconds but its now impossible to say if its the extender, the Wifi Router, the cable modem or the Monopoly (Comcast)
- MartinelloAspirant
My EX7000 is running in access point mode (a wired connection from my router to the EX7000). And when initially set up, both 5.0GHZ and 2.4GHZ are working fine.
After a few days the problem first occurred that the 2.4GHZ connection didn't connect any more. The 5GHZ connection worked fine.
Since then a reset of only the EX7000 solves the 2.4GHZ problem, but this isn't a workable situation. Since the connection drops every day!
My EX7000 is configured to get an IP address from the router. The router's wifi is disabled and there are no other broadcasting devices on the wifi channel.
So, I'm not happy about the product either. Not exactly the same device, but exactly the same problem as described in the topic...
- MarkNCAspirant
Same problem here. Right out of the box. I had to switch AT&T unite pro modem to 2.5GHZ only as some devices in house do not work on 5GHZ.
Hi MarkNC,
Which firmware version is your EX6200 currently on?
Try updating to latest firmware:
http://support.netgear.com/product/EX6200- MarkNCAspirant
I did update to the latest firmware when installing a few days ago. Also checked it again just now through the genie. Still having same problem. I have to just shut off the 5ghz and run with the 2.5.
- amoAspirantChalk me up as another very disappointed Netgear customer with an EX6200 which performs *appallingly* in Fastlane mode with the latest firmware. 5-6Mbps is a common speed for 2.4Ghz clients, despite the EX6200 getting a good 5Ghz (300Mbps) signal from the main router.
FYI, similar reports here:
http://www.snbforums.com/threads/ex6200-disappointing-2-4-ghz-speeds.16672/
I will raise a support ticket with Netgear, but others' experiences aren't filling me with hope that Netgear will fix it any time soon. I hope I'm wrong... - amoAspirantHahaha... awesome support from Netgear - NOT! Following the support links to get to a live chat session...
Marie: Thank you for choosing NETGEAR.
Marie: My name is Marie with Expert ID 46279. How may I assist you today?
Alan Ogilvie: Hi. I have been experiencing extremely poor performance with my EX6200 in Fastlane mode. This problem has also been reported by other users on Netgear Community forum
Alan Ogilvie: https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/EX6200-drops-2-4GHZ-connection-every-day-or-so/td-p/972002/page/6
Marie: I see. I apologize for the inconvenience this might have caused you, Alan. However, you have contacted Arlo, NETGEAR's support for monitoring system. Please allow me to transfer this session to the appropriate department for them to be able to further assist you.
Alan Ogilvie: I posted to the forum a few minutes ago.
Alan Ogilvie: Thank you
Marie: You're welcome, Alan. Again, thank you for choosing Netgear. Have a great day!
Marie has disconnected.
Brian Paulo: Thank you for choosing NETGEAR.
Brian Paulo: My name is Brian with Expert ID 46378. How may I assist you today?
Alan Ogilvie: Hi. Can you see the message I typed above?
Alan Ogilvie: Regarding the performance of my EX6200
Brian Paulo: Alan, you are through to the presales group and I will not be able to help you today with your NETGEAR EX6200 extender, however, if you click on correct link on Contact Us page for post sales group, one of my colleagues will be glad to help you with your inquiry. Thank you and have a good day.
Brian Paulo has disconnected.
Utterly pathetic. - amoAspirantOk, so I finally managed to raise a support ticket. I'll report back for everyone's benefit if and when I have any (good) news...
- amoAspirantSwitched back to non-Fastlane mode, and things seem a lot more stable. Let's see how long that lasts...
- amoAspirantOMG, Netgear support really is the pits.
"We are sorry to inform you that your NETGEAR product's support warranty(90 days of email support) has expired and we will not be able to provide you further technical assistance via email. We are sorry for the inconvenience caused."
Uhhhh...I bought the product on 6th November 2015, which is 64 days ago. Get a better calendar!
If this is the way Netgear treat their customers, it's a pretty safe bet that I won't be buying their products in future. - amoAspirantJeez, I feel stupid. It appears that I recorded an incorrect purchase date (year 2014 instead of 2015) in Netgear MySupport.
So *I* am the one who needs a better calendar :-)
