Prokur's avatar
Prokur
Follower
Sep 22, 2016
R6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function.
The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every time I click "configure" in Facebook Wi-Fi page, browser takes me to erroneous page: https://www.facebook.com/wifiauth/config?gw_id=
After that Netgear Genie becomes irresponsive and only reboot helps to get again into Administration panel.
Perhaps somebody can hlep me?
I suspect that Facebook has changed the page url for this kind of configuration.
What is the right Facebook page link to configure such things?
Perhaps it may help. Router is phisically located in Latvia.Serial Number: 44015177012F1
  • Hi kazaven,
    Please make sure that you are connected to the Guest Network and not to the main network.
    Dexter
    Community Team
  • Hello I have same problem with configure link. Is there any solutions?
    As soon as press config button I am getting redirected to facebook page which says
    Sorry, this page isn't available The link you followed may be broken, or the page may have been removed.
  • I notice there has been no solution posted to this as of yet. I PM'd Dexter and was told I would be contacted by a support expert but have not yet heard.
    I actually got a working solution by downgrading the firmware. I downgraded the firmware to 'Firmware Version 1.0.3.28' available here.
    But... and it's a BIG 'but'...
    The splash page / Facebook check in page is completely bypassed and does not appear for https requests - that is - basically the entire web nowadays. e.g. Google, Facebook, phone apps including 'what's app', etc.. Completely unfeathered access with no gains from the Facebook hotspot service.
    I am not sure yet as to whether this is a constraint of Netgear or of Facebook. Does anyone know? A few searches have lead to me believe the issue exists on other Facebook wifi enabled routers.
    I have toyed with the idea of blocking the https port so that all traffic runs over http therefore ensuring authentication through Facebook check in. I am just unclear right now as to the implications of that i.e. will websites work e.g. gmail, google search etc. or throw an error. And of course consumer trust. Thoughts?
    • _R's avatar
      _R
      Initiate
      Let me elaborate more.
      (tl;dr: If you want a really working Facebook Wi-Fi solution, find an alternative, I've finally used a gateway from a cloud-manged brand, it worked really nice but I have to pay both hardware and yearly fee)
      (Declaration: Not IT professional, now deployed FB Wi-Fi Solution from another brand instead, and my 6300v2 is now vacant)
      Initially I checked Facebook Wi-Fi supported list showing quite some brands (some are pricey enterprise products, and some are more affordable/residential ones), among the list I chose R6300v2.
      However, the Facebook Wi-Fi worked in a way -- Blocking Port 80 only and leaving all the rest ports opened, this is probably the laziest solution since almost no firewall rules are being touched, the router just tap 80 connection, moreover, since HTTPS is blocked and Facebook has been using a CDN (i.e. you can't determine what website the client is requesting), if they block HTTPS it will be too difficult to implement, so they left HTTPS (and other non-80 Ports) free. (Technical side: I think they just deploy a simple proxy server to divert all 80 traffic with a gatekeeper mechanism, non-80 traffic are directly routed out)
      However, the world has changed a lot. Nowadays, most applications are using HTTPS as primary protocol (Google, Facebook, WhatsApp.... you name it!), even Google Chrome and some other browsers are prompting unsafe alert in non-HTTPS website, and under the current working mechanism, all these websites and services are freely accessible (without doing checkin/code/not even a button), not only HTTPS, if you got a VPN (Whatever, PPTP, L2TP or just SSH Tunneling), by connecting it you have jail-broken the walled garden, so the Facebook Wi-Fi feature is basically useless.
      Well, Netgear is not the only brand that have such problem, you can enjoy non-80 port access other consumer brands (some enterprise brands, too) Facebook Wi-Fi routers.
      The ultimate, technical way to solve this is implement a firewall-based mechanism, blocking all non-Facebook connection (regardless ports), the description in this open souce package has enough insight to make facebook IPs inside walled gardened (tl;dr: Cache DNS queries, and dynamically releasing IPs that matching Facebook/FBCDN domain names Reference: https://github.com/mhaas/fbwlan), the large memory and flash size is more than capable to incorporate such features. It's up to how much works Netgear would like to done. (Well, maybe it isn't Netgear's fault, if you look into GPL of R6300v2, FBWiFi part is precompiled, and you may notice other consumer-grade routers with Facebook Wi-Fi are all ARM-based, maybe it's Facebook's issue, but unlikely, it's rather someone not want to disclose the code)
      If I have access to the official API on FB Wi-Fi, I would never buy this router.
      • As everybody here, I have the same Issue, I have written Facebook and they don't reply. Even wrote Mark Zuckerberg, no answers either. Is there anything ? Or has this system ever worked before?
        Thanks!
    • kazaven's avatar
      kazaven
      I have a netgear r6300v2 with latest and when I set up the facebook wifi it allows me to connect and surf the internet but it doesnt require me to check into my selected facebook page. How do I fix this?
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi kazaven,
        Dexter
        Community Team
  • Omg,
    Same problem with me here ! I had old NightHak R8000 which not support FB wifi, i did bought one R6300v2 on amazon but today i configure FB wifi then stuck at link: https://www.facebook.com/wifiauth/config?gw_id=
    I need to Unplug to restart the router .... but same problem happened.
    Please help !
    • pugwash1971's avatar
      pugwash1971
      Tutor
      I downloaded the latest firmware and it didnt work.  I then downloaded the previous version and the Facebook wifi link did work and I was able to set it up.
      It worked on my phone when I tried it, but when my customer did the same, he got a different response.  My phone is Android, his phone is Apple.
      In any case whether you get it to work or not, its a waste of time because users can "skip check-in" which totally defeats the reason for having the option.
      The way the product is marketed says that users "check-in and like your page before getting free wifi".  This is incorrect and false advertising.
      You can hit the business Facebook page and "skip check-in" and still get free wifi.  So whats the point ??
      I dont have enough money to take on Netgear in court over false and mis-leading advertising but if I did, I would.
      In fact I have less money now from when I started on this project as I have purchased the router but my customer, quite rightly, wont pay me for it as it doesnt do as it was supposed to do.
      • mariusme's avatar
        mariusme
        Dear Sir,
        Other routers listed on the facebook page are also acting the same way, I've tried a couple of models now, so the customer (coffe shop ...) should know that not all customers will share location or like their page.
        thank you
  • hi pugwash1971,
    After logged in ... at the Facebook wifi configuration there have an option to enter your private key if user skip check-in
    Btw, for problem stuck at https://www.facebook.com/wifiauth/config?gw_id=
    I figured out that my router is not configed access internet via Internet port and provide it own DHCP. After re configed internet port... my 'facebook wifi' is successfully set up
  • DexterJB Prokur rojarrolla _R mariusme xuandna I have been checking what is going on when you click on the "configure" button in the Facebook WIFI section, turns out the page is totally broken, whenever you click on that button there is a script in the browser calling to a PHP (sic) script named config_fbwifi_gwid.php that script return a pretty useful empty response which is why we get no id or no token to send to FB, looks like this has been disabled intentionally because there are other lines commented out in the same script, here is all the evidence:
    And then there is this totally useful response from in their "production" ready setup service:
    I may have misconfigured my router yet I followed all the guides in Netgear´s website at no avail, I rest my case, I hope the crew at Netgear could acknoeldge their product does not perform as advertised and at least have the decency to return the money back, Your move Netgear.
    • jtanori's avatar
      jtanori
      Initiate
      DexterJB I did never receive the patched bundle the support team promissed, I did signed the NDA and everything but no response back, this is obviously going nowere, nice customer service.
    • rojarrolla's avatar
      rojarrolla
      Tutor
      So far I  have not found any solution, and neither Netegear nor Facebook care about it, I just went with hotspotsystem and they have some free plans that can work very similar as a promissed by Netgear or Facebook.
      Grüsse!
      • xuandna's avatar
        xuandna
        Guide
        Hi, my experience to solve this problem is:
        1. Router must be configured Internet port and it status said: GOOD with green color :D
        2. Guest network is none password
        3. Access your Router by SmartPhone with facebook Signed out
        RETRY if you success let me know
