funkygecko's avatar
funkygecko
Can't connect to ReadyCLoud, but connects to Raidar...
Ive had my ReadyNAS 102 for a few years and its worked fine. I have it setup to link directly through ethernet from Rn102 to my iMac. I have the unit setup with Time Machine for my backups, and a month and half ago it said it had to do a new reboot of the unit and start a fresh Time Machine backup. As an aside, i have the new OS Sierra on my iMac.
Long story short, the Time Machine can't make a new backup, so i thought i'll log into the ReadyCloud and wipe it and start with fresh drives. However now my computer doesn't see the RN102 through readycloud. The odd thing is is that RAIDAR can see the unit, but readycloud can't find/discover it.
I'm thinking maybe the OS Sierra update did somethign wonky....honestly any recommendations are welcome. Thanks!
  • StephenB's avatar
    You can start over w/o using readycloud. Can you access the web UI directly?
      • mdgm-ntgr's avatar
        mdgm-ntgr
        NETGEAR Employee Retired
        Which firmware is the RN102 running?
        Is the correct serial number showing for the RN102 in RAIDar? If not that will need to be fixed before you update to 6.6.0.
ProSupport for Business
