Deo3000's avatar
Deo3000
iPhone ReadyCloud can not connect internarnally to ReadyNas 104 OS 6.9.3
ReadyCloud in the iPhone does not connect internally (when I am in the same network). ReadyCloud in the iPhone can connect when in the Celular network or in another WiFi.
ReadyCloud in the Mac can connect internally.
ReadyCloud in the browser works internally and outside.
I  can connect using the <IP>/admin also.
I already forward the port, set an static IP address, enable/disable encryption without success.
What is the solution?
  • Deo3000, Radek71
    There is new version for the Readycloud app for iOS (2.0.2). You may try installing that version and see if that will resolve the issue.
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi Deo3000,
    Welcome to the Community!
    1. What is the version of the ReadyCLOUDapp installed on your iPhone?
    2. Are you able to access NAS via ReadyCLOUD portal using your iPhone's web browser?
    3. If you have another iOS device, are you getting the same issue as well on the ReadyCLOUD app?
    • Deo3000's avatar
      Deo3000
      Hi John
      Version 2.0.1,(2040)
      Yes, I can connect with my IPhone web browser using the readycloud.netgear.com and directly <ip>
      Yes, I have an iPad
      • JohnCM_S's avatar
        JohnCM_S
        Deo3000, Radek71
    • Radek71's avatar
      Radek71
      Hi John,
      I have exactly the same problem:
      - ReadyCloud connection works fine from web browser - internal (home) network and also internet.
      - ReadyCloud connection works fine from Android device - internal (home) network and also internet (wifi or LTE). App version is 1.2.11 (last one).
      - ReadyCloud connection works fine from iOS device iPhone and iPad - external network, internet (wifi or LTE). App version is 2.0.1 (last one).
      - ReadyCloud connection does not work from iOS device iPhone and iPad - internal (home) network. App version is 2.0.1 (last one). There is information window: Error/Network error occured.
      Regards
      Radek
      • JohnCM_S's avatar
        JohnCM_S
        Deo3000, Radek71
        I did not encounter this issue when I simulate this on our end. May I know the iOS version of your Apple devices?
ProSupport for Business
