tdaters's avatar
tdaters
Readynas Pro with os6 will not connect to Readycloud
i have an old readynas pro 6 with os6 installed. It won't connect to Readycloud because the nas spits out the mac address on eth0 as the serial number.
i have seen posts on a work around, just nothing current.
thanks
tim
  • Hi tdaters,
    The fix has been applied and the NAS has been rebooted to Normal mode. It should have the proper serial number now.
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi tdaters,
    Can you enable SDM (Secure Diagnostic Mode) on the NAS? We will try apply a fix for that problem. Please PM me the 5-digit port number after enabling it.
    • Retired_Member's avatar
      Retired_Member
      I have the same problem
      After Update to 9.4. and change the network DNS to 8.8.8.8 and restart the serialnumer change to NONE000200000.
      I cannot use READYCLOUD.
      It was changed before from stephenB and i could use Readycloud.
      But after a restart i got again NONE and no connection to READYCLOUD
      with best wishes
      Jochen
    • JohnCM_S's avatar
      JohnCM_S
      Retired_Member
      Your NAS has a different cause on why it cannot connect to ReadyCLOUD. L3 tried accessing it remotely but it is unreachable. Please re-enable SDM so we can check again the issue on your NAS.
      • tdaters's avatar
        tdaters
        Thanks for helping
        I have re-enabled sdm
        Same port number
        Thanks
        Tim
ProSupport for Business
