Wildtexaschef
Dec 01, 2014Aspirant
6.2.0 has no manual to download
There is no manual for the new firmware 6.2.0 release.
A manual is needed to explain in better detail the new features, how to use them and what they are.
I have several question in regards to 6.2.0
1. What is "scrub", how does it work? What does it do? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
2. What is balance? how does it work? What does it do? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
3. I do know what defrag is, but how does netgear implement it? how does it work? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
4. Disk test, how does it work? What does it do? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
5. In regard to the auto power on and off. If the NAS is busy doing a scrub, balance, defrag, or disk test. Will it turn off or will it complete the task then turn off? Same goes if it's busy with a backup or replicate. Will it turn off in the middle of those tasks as well? Or will it completed them first before turning off.
6. If the unit is powered off automatically, and there is a scheduled task to start at a time that the unit is powered off, will it automatically turn on and start the task? Or must we schedule the unit to power on before the task is scheduled to start?
Those are just some of my questions I have that can't be answered from reading the manual to 6.1 firmware, and you have not released the manual for 6.2.0
- btaroliProdigyRight, so bitrot protection, in this scenario, is Netgear's shorthand for checksum + self healing. I really did a double take when I saw that entangled with CoW... since you really don't need CoW to do bitrot protection. It is interesting that you note that some of this happening at the md5 layer (where the stripe is) and some at the BtRFS layer. Nice to know it's there, though. :)
- mdgm-ntgrNETGEAR Employee RetiredWhere did you read that CoW is not necessary for Bitrot protection? BTRFS checksums depend on CoW and these checksums are in turn essential for bitrot protection.
- btaroliProdigychecksums and, more specificially, healing, rely upon BtRFS's (or md5 if that's the layer it's happening in ROS6) knowledge of extra copies of blocks and/or parity information at the block level with which it can attempt to recovery from checksum errors. That protection, in BtRFS, occurs even if I choose to disable CoW on a folder (like the one I keep my VM's in). Can I still snapshot that path? You betcha! I do it every single day in my Linux environments. And, yes, the snapshot will result in CoW as data diverges from the snapshot... but once the new blocks are written for the +COW path(s), it stops doing additional CoW on those blocks.
Yes, that can get messy after a long while... but it's part of the mix to be aware of when tweaking around with filesystem behavior. :)
Perhaps some details will diverge from this in terms of how Netgear implemented it (bringing md5 and BtRFS together), but without documentation that's hard to say. I can confirm how it works in a pure BtRFS environment. - WildtexaschefAspirantThe large files are HD MKV/MP4 video files in the size of 25gb to 35gb.
So once written, they are only read. - btaroliProdigyThen I really wouldn't worry so much about having CoW enabled... and the bitrot protection will likely be of great interest. :D
- btaroliProdigyOh, that's hilarious. I just tried creating a new folder (share) on my 6.2.0 env and was quite amused by the default:
So I guess it certainly does allow for no COW and snapshots. ;) Or is that no bitrot protection and snapshots? This UI is very confusing, tying together two functions that aren't usually combined. It would be nice to be sure what that little checkbox does. I think I'll be keeping it turned on for my shares, in any event, since I rather like checksums AND CoW. - btaroliProdigyDigging around a little more, I was looking at the new home dir setup options -- I rather like this change by the way! I see that we can now enable snapshots -- does that include personal TimeMachine vaules, if enabled, by the way? But I also see a per-user "Protection" checkbox. Does that translate to the "Bitrot Protection (COW)" on regular shares, or is it something else?
- mdgm-ntgrNETGEAR Employee RetiredWell the way we have implemented BTRFS using md raid would make some things different to simply using BTRFS.
https://btrfs.wiki.kernel.org/index.php/FAQ indicates that if you mount a volume with CoW disabled then checksumming is turned off. This suggests to me that checksums do depend on use of CoW, perhaps a bit like how snapshots make use of CoW.
Bitrot protection (well at least our implementation) does depend on CoW. If Bitrot protection is disabled then CoW is disabled.
Snapshots are enabled by default on x86 systems. Snapshots will work when CoW is disabled as has been discussed earlier in the thread. - mdgm-ntgrNETGEAR Employee Retired
btaroli wrote: Digging around a little more, I was looking at the new home dir setup options -- I rather like this change by the way! I see that we can now enable snapshots -- does that include personal TimeMachine vaules, if enabled, by the way? But I also see a per-user "Protection" checkbox. Does that translate to the "Bitrot Protection (COW)" on regular shares, or is it something else?
Yes snapshots for home shares is one of the new features in 6.2.0
Personal Time Machine is stored under /data/.timemachine so I don't think so.
That checkbox might be referring to snapshot protection. Can you post a screenshot? - btaroliProdigy
mdgm wrote: https://btrfs.wiki.kernel.org/index.php/FAQ indicates that if you mount a volume with CoW disabled then checksumming is turned off. This suggests to me that checksums do depend on use of CoW, perhaps a bit like how snapshots make use of CoW.
I see... mount options. OK. I get that. And I should clarify that, in my environments, I leave all default filesystem features enabled but selectively disable COW on a sub-folder level, and very selectively. If I only wanted COW enabled on a limited basis, I'd just split the activity off into it's own subvolume (or, in ROS6-speak, folder/share).
