diverguy's avatar
diverguy
Dead ReadyNAS Ultra2, how to retrieve files?
Hi, I have a ReadyNAS Ultra 2 with two WD Green 3TB drives of which the LCC problem was solved by applying the WDIDLE3 tool early on.
The other day I wanted to detach the MyBook 3TB that I use for backups (Ultra2 was working fine so far) to see if the drive was still good because all my Rsync jobs were suddenly failing. The failing is most likely because of ownership issues. BUT...before detaching the MyBook I shut down the Ultra2 for a clean detach. After that the Ultra2 never wanted to boot again. Not with original drives, not with zero drives, not with 1 brand new drive. No activity on either ethernet port either. Only the blue light comes on and the fan changes between 2 speeds and both those speeds are faster than under normal operating conditions.
So far the description.
Now the real question: how do I get to my data? I figured since this is a unit with an Atom CPU, the drives should simply turn up on a PC with EXT3 partitions? Without having to deal with the Sparc issues? Even when RAID1 is involved?
I tried USB to SATA interface and directly to SATA on motherboard. I tried Win7 with tools that allow to read linux partitions. I tried a live Linux distro (Knoppix 6.4) and I tried the following recovery software:
1. Stellar Phoenix Linux Data recovery (which served me well with a crashed Thecus in the past)
2. Zero assumption recovery
3. Diskinternals RAID recovery (shows high file and folder count while scanning but produces garbage)
No meaningfull coherent data, at all !!
I should mention also that because of the backup problems with Rsync, they are not really current anymore because I was patiently trying to learn what was wrong to remedy the problem. And now I'm stuck with 2 months old backups. So I'm REALLY eager to retrieve my data.
Disk management of Win7 shows three "healthy" partitions on each disk. One 4GB, one 512MB and one 2790GB.
Is there anything that I missed? What would the recovery software of choice be that doesn't break the bank?
Anyone of the guru's please?
ProSupport for Business
