ahoffer's avatar
ahoffer
Power Supply replacement compatibility
I do believe the power supply in my Infrant ReadyNAS RNV1-S2-0000 has died. I bought it in October 2006 from Newegg. The power supply died once before and [then] Infrant replaced it. Now it looks like it's my turn turn to replace it. I've spent a lot of time researching replacement power supplies and it looks like I can buy a replacement off-the-shelf for $100-$125. I'm fine with that.
I can buy a NETGEAR branded power supply, the RND4PSU1-10000S, from one of several vendors:
http://www.esecuritytogo.com/ProductInfo.aspx?productid=RND4PSU1-10000S
http://www.pcconnectionexpress.com/IPA/Shop/Product/Detail.htm?sku=8182865
http://www.amazon.com/gp/offer-listing/B000W3X480/ref=dp_olp_new?ie=UTF8&condition=new
Before I go through the hassle of buying one of these units and trying it out, I want to check with the ReadyNAS community to confirm that this unit will work for me. Thanks in advance.
-Aaron
ProSupport for Business
