mule
Jul 28, 2010Aspirant
ReadyNAS Pro: System temp running out of spec
In the last weeks I did have several times where the CPU temp ran out of spec. What's annoying to me is that the cpu fan runs at maximum 1506 rpm?! Shouldn't it rotate much higher to avoid temp running out of spec?
Any idea what to do? A calibration of the cpu fan is not offered within frontview...
Thanks in advance for any hint!
- muleAspirant@chirpa: Did you receive my log files? Any news regarding this issue?
- chirpaLuminaryPlease try T11, viewtopic.php?f=51&t=43739
- muleAspirantSince install of T11 CPU Temp went 5-6 degrees down. Seems that beisser was right. Thanks for fixing, chirpa!!!
- muleAspirantSorry wrong info: the at first sight recognized lower temperature may have been caused by the reboot after upgrading to T11. Now after reading and writing from/to the readynas temp1 is at 64 degrees again and the cpu fan maxes out at around 1500 rpm...
- chirpaLuminaryCan you try 4.2.11, and see if it works better as beisser mentioned? This will help narrow down the issue.
- muleAspirantWill do the test. Anything to consider before/while downgrading to 4.2.11?
- bollarAspirantI am still having this issue occasionally with T11:
Temperature sensor 1 reports out of normal range [expected range: 0-65C/32-149F, current: 66.0C/150.8F].
- muleAspirant@bollar: Just to be clear: Do you mean with 4.2.11 or 4.2.13-T11?
- mattseattleAspirantHe said ---> Can you try 4.2.11
- bollarAspirant
mattseattle wrote: He said ---> Can you try 4.2.11
He also said: Please try T11, viewtopic.php?f=51&t=43739
I'm confirming that I see the same issue as the OP with T11.
