mervincm's avatar
mervincm
ReadyNAS RN104 ESATA+USB
Having some difficulty finding use for these port, so I have some questions
ReadyNAS 104 with 4x1TB Seagate 7200 in (RAID 5) XRAID 6.0.8
-Does it support Hot swap on the ESATA, or must you add it then reboot the NAS?
I have not had any luck getting it to see any ESATA devices yet.
-Once it is detected does it show up?
-Does it support Hot swap on the rear 2 USB3 ports or must you add it then reboot the NAS?
I connected a spart USB3 HDD to the top port, and it didn't seem to be usable till after I rebooted the NAS. Then it appears shared but asking for credentials even though I have not created any accounts yet.
  • evan2's avatar
    evan2
    NETGEAR Expert
    Which eSATA model do you use? You had better reject eSATA driver firstly on UI, then unplug eSATA.
    For USB3.0, You also had better reject USB driver firstly on UI.
    I have a RN104
    http://www.netgear.com/landing/storage/for_home.html#tabs
    It lists eSATA expansion port
    If you were asking about my external Esata enclosure, I tried a couple including a
    4 disk ESATA enclosure (to test it if supported a port multiplier on ESATA) (was not sure how to tell if it worked)
    2.5" seagate freeagent goflex ESATA (no ESATA power)
    I appreciate your attempt to respond, but I do not understand what you are suggesting. It appears you are listing what I should do to safely remove a working shared external drive. I should "Eject" the "drive" in the UI then unplug the external device.
    I am not having problems disconnecting working drives, I am asking questions about what to expect when I hookup new external drives via USB and via ESATA.
  • evan2's avatar
    evan2
    NETGEAR Expert
    Yes, it support
    I don't have 2.5" seagate freeagent goflex ESATA, I need to buy one and check the issue.
    if the device is detect, system will auto mount eSATA/USB volume, then esternal driver will be shown up in UI(System/Overview page).
    Yes, it support, but we don't test all USB3.0 device,
    Coulld you tell me which USB3.0 driver do you use?
    I used the below USB disk,
    USB3.0 Flash
    Kingston DT Ultimate 16GB
    Corsair USB 3.0 16GB
    Super Talent USB 3.0 16GB
    Super Talent USB 3.0 8GB
    USB 2.0 Disk 2.5"
    WD USB2.0 500GB WDBABV5000ABK-00
    USB3.0 Disk 2.5"
    TOSHIBA USB3.0 500GB E05B050CAU3HS
    TOSHIBA USB3.0 1TB E05B100PBUEAL
    WD USB3.0 320GB WDBACY3200ABK-00
    WD USB3.0 500GB WDBACY5000ABK-00
    WD USB3.0 1TB WDBACX0010BBK-01
    ADATA USB3.0 500GB ACH11-500GU3-CBK
    Iomega USB3.0 1TB RPHD-UG3
    USB 3.0 Disk 3.5"
    Seatate USB3.0 2TB 9SEAN2-500 ===>Don't support.
    ioSafe SoloPRO USB 3.0 1TB SJ1000GB
    LaCie USB3.0 2TB Porsche design P9230
    WD My boOK essential 3TB WDBACW0030HBK-01
    USB3.0 Docking
    Thermaltake BLAC X 5G
    NexStar CX Super Speed
    ORICO 8628SYS3-C (eSATA+USB3.0+Clone)
    USB3.0 HUB
    Syba USB3.0 4-Port HUB
    Syba USB 3.0 4-Port HUB
  • Thanks for your reply. I typed in a large update yesterday, but my session timed out and it was lost before post.
    Using a standard, single disk, vantec NX3 enclose and linux or MBT/NTFS disk I was indeed able to verify that this model does indeed support HOT-ADD of eSATA Disk and USB2 Disk they are auto mounted.
    I saw no support on USB3 with my Seagate 1TB freeagent goflex using its swappable USB3 interface. I can confirm it did work on the front USB2 connector
  • Also the link in your sig
    http://kb.netgear.com/app/answers/detail/a_id/20683
    It does not contact documentation for the new products, you might get that to your web content team for update.
  • evan2's avatar
    evan2
    NETGEAR Expert
    Hi Mervincm,
    My Seatate USB3.0 2TB 9SEAN2-500 works OK on the front USB2.0 port.
ProSupport for Business
