adb1's avatar
adb1
Unresponsive ultra 2 plus
This morning my U2P was not 'visible'. ping does not work - destination host unreachable. Power button would not shut down the box and no access to Frontview.
I rebooted with 5 second power off then power on again. RAIDar sees the box booting and file system check shows 100%, then the device disappears from RAIDar.
I have done various reboots and at one point, after moving the box to another place, I could connect to Frontview and checked the logs and it had nothing wrong. I started to download the logs then the device disappeared again and I could no longer access it.
It seems like sometimes the device can be pinged, other times it's not reachable. I tried both ethernet ports, different cables, different routers, but in all cases now I cannot map the drive in Windows and I cannot use Frontview to access the box and the box has to be shut down with the 5 second hold.
I ran wireshark when trying to access the box with Frontview and I see lots of TCP SYN packets, followed immediately by RST/ACK from the NAS. Having rebooted for the nth time, ping is responding this time.
Interestingly, if I ssh to the box now, I get the TCP connection, e.g. SYN/SYN-ACK/ACK, but then nothing else from the box...
It sounds like a network hardware issue - we have had some odd problems over the last month which could have been network related. Is there anyway to connect a PC directly to the NAS without using a router?
Anyone seen anything similar?
ProSupport for Business
