tarobun
Nov 24, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091.
If it doesn't work after installation, try rebooting.
Not sure if it can be install over the top of super-poussin's version, but if you are planning on uninstalling super-poussin's version then remember to save the torrent files somewhere else first.
To quote myself:
Thanks to super-poussin for the original Transmission add-ons.
Enjoy!
Transmission_2.73.bin - http://www.mediafire.com/?ajpyyc7ujv54o37 no-utp
Transmission_2.75.bin - http://www.mediafire.com/?gbmbhu3hrabf9fe
Transmission_2.76.bin - http://www.mediafire.com/?389i53w9w9rtosm
Transmission_2.77.bin - http://www.mediafire.com/?pm420vuajaim9bz
Transmission_2.80.bin* - http://www.mediafire.com/?5s7dag8ko72doj1
Transmission_2.81.bin* - http://www.mediafire.com/?x4pvvidrgb36df2
Transmission_2.82.bin* - http://www.mediafire.com/?rbctsdae000zoav
Transmission_2.83.bin* - http://www.mediafire.com/?31iul25i0t12qda
Transmission_2.84.bin* - http://www.mediafire.com/?rh5fge4mc8ahzw4
*if the "Upload" button doesn't work or the "Destination folder" field is blank, reload the webpage.
To quote myself:
tarobun wrote: It looks like upgrading from Transmission 2.42 to this Transmission add-on is a no-no. Sounds like there are conflicting configuration that screws up both installs. :( (eg. /c/addons-config)
It seems the best approach is to fully uninstall the old, delete the config directory, and then install this add-on. Once you're on this add-on, updating is straightforward and can be done over the existing version.
Just a fyi - the default download dir is /var/local/Downloads and there is no username and password with this add-on. If you are prompted for them then the old version was not fully uninstalled.
Enjoy!
- wilwaiAspirantThank you very much for the 2.81 it run so well in my NV+ :)
However, did the watch directory function still working on 2.81?
Dose the following text still working?
"watch-dir": "/c/media/BitTorrent/sources/",
"watch-dir-enabled": 1
Thank you very much. - tarobunTutorJust tested watch-dir and it works fine.
Make sure the directory exists and use
"watch-dir-enabled": true - tarobunTutor
Russell Coight wrote:
One problem though, I'm unable to delete any files/folders that transmission has downloaded, permission error. Permissions are nobody/nogroup.
Is there anything I can do?
Hmmm... not sure. That's the default permissions which is recommended by the transmission team to be "world-writable" (umask=0).
Maybe try playing around with the "umask" setting in the settings.json? Might need to do a bit of reading. :) - Russell_CoightAspirantumask 0 fixed it :)
I had cracked the shits woth Transmission and seriosuly considered upgrading to a newer unit, hoping that would fix the issues, don't have to now :)
Donation coming your way :) Thanks for putting the time into old units like these. - tarobunTutorThanks for the donation. :)
Much appreciated! - spacecrapAspirantHi there,
I just upgraded to Transmission 2.81 and found out that I could enter the transmission web interface, but:
- all the downloads are gone from the overview (I probably have to add this manually?);
- New downloads won't start downloaden.
I have an open port, but the downloads just won't start, what can I do to fix this?
edit; strange.. it seems that the RPC port was still on 8181 in stead of 9091.. i changed this in the .json and one of the downloads works now... the other ones don't yet.... - tarobunTutorUpdated to version 2.82 - dedicated to Russell Coight
Changes:
All Platforms- Fix webseed crash
- Fix crash when adding UDP trackers whose host's canonical name couldn't be found
- Fix crash when sending handshakes to some peers immediately after adding a magnet link
- Fix crash when parsing incoming encrypted handshakes when the user is removing the related torrent
- Add safeguard to prevent zombie processes after running a script when a torrent finishes downloading
- Fix "bad file descriptor" error
- Queued torrents no longer show up as paused after exiting & restarting
- Don't misidentify Tixati as BitTornado?
Web Client- Fix syntax error in index.html's meta name="viewport"
- Fix file uploading issue in Internet Explorer 11
- tarobunTutor
spacecrap wrote: Hi there,
Hmmm... upgrading from 2.42(?) is a bit tricky as the settings.json file is retained and don't default to the 2.8x settings.
Maybe try renaming the settings.json file and restarting the addon so a fresh settings.json is created which you can then edit manually. - spacecrapAspirantThanks for your reply.
I can only change the settings.json file in the 'transmission-deamon' folder... but when I change the name and start + close down transmission nothing changes.
The issue is that the folder with the new version differs from my old version.
With the new transmission the folders 'torrents' and 'resume' can be found in the root folder (\\192.168.1.105\addons-config\Transmission)
where my old torrent files can be found in the 'torrents' and 'resume' folders which are placed in the transmission-daemon folder (\\192.168.1.105\addons-config\Transmission\transmission-daemon)
I cannot copy my old files to the new folder and I don't know what I have to change to reconfigure tranmission so my old torrents can be shared again.
Is this clear and could you help me out? - tarobunTutor
spacecrap wrote: I can only change the settings.json file in the 'transmission-deamon' folder... but when I change the name and start + close down transmission nothing changes.
Is there a settings.json in the /addons-config/Transmission/ folder? That's the one you should be changing. The other one is now unused.spacecrap wrote: I cannot copy my old files to the new folder and I don't know what I have to change to reconfigure transmission so my old torrents can be shared again.
Why can't you copy the files to the new folder? Do you get an error?
There are 2 way to get your old torrents back:
1) You'll need to move all the *.torrent files in /addons-config/Transmission/transmission-daemon/torrents to /addons-config/Transmission/torrents and change your download dir to point to the old folder.
2) Edit the /etc/frontview/addons/bin/TRANSMISSION/start.sh and change TRANSMISSION_HOME=/c/addons-config/Transmission to TRANSMISSION_HOME=/c/addons-config/Transmission/transmission-daemon (and also remember to do so each time you upgrade the addon).
Option 1) is the preferable one.
