abeman
Dec 11, 2011Aspirant
Copy of first file to NVX on XRAID2 always fails
I have a NVX with 3 disks of 1GB in XRAID2
each time after a fresh start of the NVX the first file I copy to the NVX stops during the copy
for no reason at all... after a while it fails or picks up again
eg when I use supercopier 2 I get an error message.
once it has failed once, I can transfer files just fine.
anyone else have this problem or does this sound familiar to anyone else?
or even have a solution for it? thx
- abemanAspirantHi
I can access the files on my nas perfectly, and after the first write fails, they also work fine.
from what I read on this page http://www.readynas.com/?page_id=82Added support for 4K sector drives. If you have already installed 4K sector drives with 4.2.11 or earlier, you can replace each disk one by one, allowing it to complete resync, and all your disks will be 4K aligned, and your performance should be on par with similar 512-byte sector drives.
would that mean that I could resync my drives by reinserting them or something?
how can I find out if my drives have 4k or 512B sectors? - mdgm-ntgrNETGEAR Employee RetiredDownload your logs (Status > Logs > Download all logs) and extract the zip contents. What are the contents of your partition.log?
- abemanAspirant***** partition output for sda *****
Disk /dev/sda: 1953525168 sectors, 931.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 94DDF162-9513-4B5C-8409-0FECBDC35A51
Partition table holds up to 8 entries
First usable sector is 4, last usable sector is 1953525164
Partitions will be aligned on 8-sector boundaries
Total free space is 5101 sectors (2.5 MiB)
Number Start (sector) End (sector) Size Code Name
1 4 8388611 4.0 GiB FD00 Linux RAID
2 8388612 9437187 512.0 MiB FD00 Linux RAID
5 9437189 1953520064 927.0 GiB FD00 Linux RAID
Disk /dev/sda: 121601 cylinders, 255 heads, 63 sectors/track
Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sda1 0+ 121126- 121127- 976762583+ ee EFI GPT
/dev/sda2 0 - 0 0 0 Empty
/dev/sda3 0 - 0 0 0 Empty
/dev/sda4 0 - 0 0 0 Empty
***** partition output for sdb *****
Disk /dev/sdb: 1953525168 sectors, 931.5 GiB
Disk identifier (GUID): E302ADA2-DF10-473F-9EC8-A6CBE54B08BD
Disk /dev/sdb: 121601 cylinders, 255 heads, 63 sectors/track
/dev/sdb1 0+ 121126- 121127- 976762583+ ee EFI GPT
/dev/sdb2 0 - 0 0 0 Empty
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
***** partition output for sdc *****
Disk /dev/sdc: 1953525168 sectors, 931.5 GiB
Disk identifier (GUID): F85875C1-A43E-4493-B2CD-7780CD9E7A4E
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 1953525134
Total free space is 5041 sectors (2.5 MiB)
1 64 8388671 4.0 GiB FD00 Linux RAID
2 8388672 9437247 512.0 MiB FD00 Linux RAID
5 9437256 1953520131 927.0 GiB FD00 Linux RAID
Disk /dev/sdc: 121601 cylinders, 255 heads, 63 sectors/track
/dev/sdc1 0+ 121126- 121127- 976762583+ ee EFI GPT
/dev/sdc2 0 - 0 0 0 Empty
/dev/sdc3 0 - 0 0 0 Empty
/dev/sdc4 0 - 0 0 0 Empty - mdgm-ntgrNETGEAR Employee RetiredO.K. The third disk /dev/sdc is 4k sector partition aligned. The other two are not. So you could hot-remove (remove while NAS is on) one disk at a time, wait a bit, then hot-add (add while NAS is on) wait for resync to complete and volume status to return to redundant then move onto next disk.
- abemanAspirantso I need to do that for all the disks right?
and does it matter what disk I remove add first?
what is the chance this would mess up my system?
btw thx for the support, netgear support was not much help.
and how do you know that the last one is 4k sector aligned, because of the entries the partition table can hold? - mdgm-ntgrNETGEAR Employee Retired
abeman wrote: so I need to do that for all the disks right?
No just /dev/sda and /dev/sdb. /dev/sdc (probably disk 3) is already 4k sector partition aligned. One of the logs would indicate which is which disk.abeman wrote:
Well I'm a user like you, so I don't mind, except my personal preference would be to use supported disks. Disks not on the compatibility list may/may not work.abeman wrote:
Why you might want to factory reset a x86 ReadyNAS
