jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day,
Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to be problems with the DISC2.
For my peace of mind, i have just started a full backup of the NAS.
I am then relying on people here to advise me what to do next. I need more capacity, and was planning to convert the RAID to give me 6TB capacity. However, to do that, I will maybe need to buy a new WD 3TB RED.
What are peoples thoughts here?
I also notice that when playing GoPro3HD footage from the NAS to my iMac, I experience a lot of jitter. I think it is my mac that causes that.
Thank you
SMART Information for Disk 1
Model: WDC WD30EFRX-68AX9N0 2794 GB
Serial Number: WD-WMC1T0570XXX
Firmware Version: 80.00A80
SMART Attribute
Raw Read Error Rate: 0
Spin Up Time: 6050
Start Stop Count: 3661
Reallocated Sector Count: 0
Seek Error Rate: 0
Power On Hours: 8504
Spin Retry Count: 0
Calibration Retry Count: 0
Power Cycle Count: 30
Power-Off Retract Count: 25
Load Cycle Count: 3635
Temperature Celsius: 33
Reallocated Event Count: 0
Current Pending Sector: 0
Offline Uncorrectable: 0
UDMA CRC Error Count: 0
Multi Zone Error Rate: 0
ATA Error Count: 0
SMART Information for Disk 2
Serial Number: WD-WMC1T0573XXX
SMART Attribute
Raw Read Error Rate: 102
Spin Up Time: 6508
Start Stop Count: 3645
Seek Error Rate: 0
Power On Hours: 8505
Spin Retry Count: 0
Power Cycle Count: 29
Power-Off Retract Count: 24
Load Cycle Count: 3620
Temperature Celsius: 34
Current Pending Sector: 3
ATA Error Count: 0
Thank you
- jhbinghamAspirant
StephenB wrote: I suppose you could run lifeguard on the drive (in a PC) and see if it failed.
Hi, so I downloaded WD Lifeguard Diagnostics and got some interesting results:
Disc 1: Quick Scan COMPLETED 100% PASS
Disc 2: Quick Scan FAILED
Here are the results:
DISC 1Test Option: QUICK TEST
Model Number: WDC WD30EFRX-68AX9N0
Unit Serial Number: WD-WMC1T0570693
Firmware Number: 80.00A80
Capacity: 3000.59 GB
SMART Status: PASS
Test Result: PASS
Test Time: 18:06:44, May 06, 2014
DISC 2Test Option: QUICK TEST
Unit Serial Number: WD-WMC1T0573335
SMART Status: FAIL
Test Result: FAIL
Test Error Code: 06-Quick Test on drive 2 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 2!
Test Time: 17:58:23, May 06, 2014
Guess that means that the DISC 2 is dying? Is it work running the EXTENDED TEST and fixing the bad sectors OR should I just go ahead and order & replace this drive? - jhbinghamAspirantAlso, just plugged in the Disc1 ONLY to the NAS and accessing the files is slow. I am also missing data despite running in X-RAID2 mode....
- StephenBGuru - Experienced UserIf Lifeguard is saying the the disk failed, then I suggest getting another. If you can still exchange it at the seller, you will get a new one. If you RMA it to Western Digital, they will give you are recertified return (unless you can somehow argue them into a new one).
Not sure what is happening on disk 1. You might check the logs. - jhbinghamAspirantMy brand new replacement WD Red 3TB arrived today.
I am wanting to install the two 3TB in my duo to give me 6TB space. RAID0
Any tips to have optimum performance before beginning? Format with certain cluster size?
Power save disabled?
Regards, - StephenBGuru - Experienced UserNo formatting - the duo v2 will redo that anyway.
Use jbod (two volumes), otherwise a failure of either drive will result in losing everything.
You'll be limited by the duo v2 performance, not much by the drives. So I don't see any need to tweak power save, etc. - jhbinghamAspirantYe, i am going to backup the RAID0 to two 3TB external discs, so if the NAS RAID dies, then im still safe.
Is it possible to update the duov2 RAM to make performance better? I had the original Netgear Duo 1000 and thought i was doing a good thing moving to the V2, but it seems not so much.
Thanks for your help so far! - StephenBGuru - Experienced UserI don't own a v2, but my understanding is that the memory is soldered onto the system board.
The duo v2 is faster than the v1, but it didn't last long enough for all the features to get into its firmware.
On RAID0, I still prefer jbod. You do need to balance storage between the two volumes, but getting it back up after a failure is quicker. You won't see any performance gain with single-volume RAID0, since the CPU is the bottleneck, followed by the network. Anyway, jbod is what I use on my RN102. - jhbinghamAspirantexcuse my ignorance, but what is the jbod when we talk about the v2? will it still give me 6TB from my two 3TB?
- StephenBGuru - Experienced Userjbod = "just a bunch of disks" See pages 20 and following in your user manual. http://www.readynas.com/download/docume ... Nov711.pdf
jbod does gives you 6 TB total - 3 TB in a "C" volume on disk 1, and 3 TB in a "D" volume on disk 2.
RAID0 by contrast gives you 6 TB in a "C" volume. The aggregation into 1 volume is convenient, but reliability suffers. - jhbinghamAspirantThanks for that! I can see that JBOD is definately more beneficial in the long run. I thought having the RAID0 would speed read/write speeds up, but I guess not going by what you say about the CPU.
If i insert my good disc from the xraid2 and the new blank disc, is the readynas able to switch over to JBOD and make two volumes like you mention? so i dont have to copy ALLL 2.7TB of data from my backup onto one of the newly created volumes?
Otherwise, I guess i will want to erase everything on the old disc and start afresh.
Thanks StephenB
