Orbi WiFi 7 RBE973
Reply
Nighthawk D7000 - DHCP Address Reservation not Working
GTunney
Apprentice
Re: Nighthawk D7000 - DHCP Address Reservation not Working
I've just re-applied .44 over the top of .44 already installed which keeps settings and this has resolved the issue.
Very very stange range as I tested on my laptop and that was getting 70, looks like all devices are now getting the full 70 to them.
Message 101 of 106
Good feedback. Yet more evidence that it sometimes helps to do a factory reset after flashing the firmware.
It doesn't always work to reload the save settings, but once again you've provided useful information on when it can work.
Message 102 of 106
adrenalize
Tutor
The only thing I noted with .44 is that I had to change my OpenVPN config on my client to the new one off the router - I'd not had to do that with the last couple of updates. Other than that OK so far - might double check the WiFi given other comments.
Message 103 of 106
jpullam
Guide
I just bought one and am trying to install, but with problems in DHCP reservation..
My firmware says 1.0.7.2_1.1.93
It also says GUI language version 1.0.7.2_2.1.38.2
Is this the bad version 38? Why do the numbers look so different?
Message 104 of 106
ratsalad
Star
This thread is for the D7000, that firmware version is for the R7000.
Message 105 of 106
jpullam
Guide
Sorry I didnt appreciate the difference in model number.
In case anyone finds this, I rolled the software back to 1.5, did a factory reset and then an ipconfig /release on my desktop and it started working.
Message 106 of 106
Discussion stats
Announcements
Orbi WiFi 7
