Eloge's avatar
Eloge
M4100-12GF compatibility with Mikrotik SFP Transceiver 1.5G 1310nm SM
Hi all,
can someone confirm if M4100-12GF Netgear Switch compatible with Mikrotik SFP Transeiver 1.5G 1310nm Single Mode. I have already a cisco core switch which is using same Mikrotik SFP Transceiver but some ports are not working cause cisco normaly support only Cisco SFP Transceiver only.
Thank you in advance for your help.
Eloge
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello Eloge,
    Welcome to the community!
    Although some users have been able to use SFP modules from other brands, I cannot say that it is compatible since I cannot find information regarding the SFP transceiver that you have mentioned (if you have the model number, it is much better if you can post it). Make sure that it has the same standard as our modules, click here (page 16) to view NETGEAR's compatible module for M4100 series switches.
    I hope this helps. If you have more questions we'll be happy to help.
    Thanks,
ProSupport for Business
