Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Sparc to x86
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-05
11:09 PM
2014-02-05
11:09 PM
Sparc to x86
Hi
Why won't hard drives reformat form sparc to x 86 even with a reformat. Trying to reuse 2tb sea gates from a duo to a 312
Cheers
John
Cheers
John
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-06
07:50 AM
2014-02-06
07:50 AM
Re: Sparc to x86
The real question is what you can do to work around it.
You can delete the partitions if you connect one drive to a Windows system. Then install on that one, and hot-insert the second.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-06
08:32 AM
2014-02-06
08:32 AM
Re: Sparc to x86
But I haven't got that facility or know how. All info collected said that the 312 would reformat automatically.
John
John
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-06
10:11 AM
2014-02-06
10:11 AM
Re: Sparc to x86
It should of course have done it automatically. In your first post you said "...even with a reformat..." Did you attempt to reformat? If so, how?
Do you have a scratch disk that wasn't in the duo that you could use?
If so, you can
(a) install using the scratch disk
(b) hot-insert one disk from the duo in slot 2
(c) after resync, hot-insert the second disk in slot 1.
If so, you can
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-06
11:08 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-02-07
03:00 PM
2014-02-07
03:00 PM
Re: Sparc to x86
Your unit shipped with the first production ReadyNAS OS 6 firmware 6.0.0 on it. This is very old firmware and understandably there have been lots of improvements since then. I have updated the unit to the latest firmware 6.1.6 and since no data is on the unit yet I have also triggered a factory default to get you a clean setup on the new firmware. Probably should have wiped the partitions off the disks, but hopefully the factory default does this.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
Message 6 of 6
