- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi no internet but ethernet works
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi no internet but ethernet works
So what NG router are you referring too?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What error do you get?
Are you able to connect to the wifi but it says "connected, no internet"
What actually happens?
What modem/gateway is the router connected to?
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure the wifi button on top of the router is ON. IF thats OFF, press it for 5 seconds then release. Wifi LEDS should turn ON for 2.4 and 5Ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a different firmware for that router and see if that helps it. Maybe upgrade or downgrade the firmware depending which firmware it has.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Crypto87 wrote:
Wifi will loose internet access but ethernet works fine. Have to reboot router to fix
The lack of detail there may explain why you have had so many different suggestions. (I'd avoid changing firmware until you have tracked down the problem.)
Before diving too deeply, try answering the question that @FURRYe38 asked about the modem/gateway.
Which firmware version do you have on the R8000?
Does this happen with all wifi clients?
Then there i the question from @plemans "What error do you get?"
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware Version is V1.0.4.84_10.1.84
i think the modem is EU2251 from Spectrum. Just upgraded from a Spectrum Cisco Model DPC3010. WIFI internet cuts out with both. Wifi is on just connected with no internet. I have not done a factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you have wifi problems with the old modem?
Did you reset the router when you changed the modem?
That tells it to forget settings inherited from the old modem.
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the router feel extra warm or hot on top?
How do you have Basic wireless settings and Advanced wireless settings configured? Under Advanced Tab/Advanced Settings/Wireless Settings
Your modems don't have wifi or built in routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would try a factory reset and setup from scratch.
I also recommend placing a laptop cooler under the router for additional cooling.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
